Question about JVC KD-LH7R CD Player
12 Disc CD Changer in 2002 Corvette Convertible
The magazine is stuck in my 12 disc changer in my 2002 Corvette Convertible. It powers on, and I can hear the magazine trying to load and unload, but nothing is happening. The unit was playing fine this morning, but about 30 to 40 minutes into the trip it quit. I thought it might be moisture so I turned it off for several hours, and it still does not work. How can I remove the disc cassette?
I am Eddie Whittington at boatpro@hughes.net
  • 1 more comment
  • ftillotson Feb 19, 2009
    12 disk cd change stuck in 2001 corvette convertible
  • miller6651 Mar 03, 2009
    I have a 12 disc Pioneer changer in my 2002 Corvette Coupe. Same problem no solution as of 3/2/09
  • Anonymous Apr 09, 2009
    Same thing here....2002 Vette with the 12 disk Cd changer in the trunk area...makes noise as though it's sifting thru the cd's but doesn't pop out. Nor does it play thru the radio....i'm going to pull the thing out of the trunk and see if i can take it apart somehow...
I had this problem on my 2001 Corvette. I took the whole thing out, took off the cover and was able to get the jammed cartridge out by carefully pulling the stuck tray out of the carriage and then removing the entire carriage. Check to make sure your individual trays are not warped. Mine continued to work without problems for about three months and then it happend again. Another thing you can do is not to load a disk in the last (#12) slot. I think it's the one that gets stuck.
Posted on Nov 11, 2009
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
Mercedes cd changer stuck
There may be a CD that did not completely return to its slot in the magazine, for example if power was turned off before the return was completed. Don't know how to fix it. You might power up and try a load-unload cycle to get back to normal.
Sep 12, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
The magazine for my CD 12 disc changer will not eject nor will it play ant CDs. It seems to be getting power as the light inside the slide door lights up as open to eject the magazine any suggestions? It...
theres usually a reset button hidden inside the door on the cd changer. use a paperclip to reset the device. sometimes theres a reset on the controller part of the cd changer Up by the radio ( if you have tha type )
Jul 31, 2010 | Pioneer Car Audio & Video
Magazine is stuck inside the ch3083 cd changer. How can I get my 8 disc magazine out of the player?
you have to pull the 4 retaining screws and remove the cartridge manual if it gets stuck
Aug 23, 2009 | Eclipse CH3083 8-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Disc stuck in cd changer
there is a large gear on the top of the cd mech, turn it counterclockwise to put the cd back in the magazine. the changer will probably work after that.
May 09, 2009 | Car Audio & Video
JVC CH-X1100RF 12-Disc CD...
50 % OF THE TIME THE MICRO CHIP NEED TO BE RESET CUT ALL POWER FROM UNIT LIKE UN PLUGING CABLE FROM BACK OF CHANGER FOR 5 SEC LET ME KNOW
Jul 13, 2008 | JVC CH-X1100RF 12-Disc CD Changer
Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Jan 04, 2008 | Pioneer CDX-P1280 12-Disc CD Changer
CDAC ER2
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
hope this helps,
trin
Nov 17, 2007 | Clarion DC625 6-Disc CD Changer
JVC KD-LH7R CD Player Logo
1,392 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
