Question about Ingenico eN-Touch 1000 Digital Pen
Going from one POS system to another
I having an issue programming the new POS system over the old. Is there a way to format the En-Touch
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 6 Answers
Sure, I was also faced same problem, but you don't have to worry about to change your posting system. You can easily transfer ordering information from old to new. At the same time, it tracks menu items that can be stocked over a period of time. If you want a good POS system I prefer Hospitality Resource Directory in Singapore. A vital source that can provide and give the complete information of the POS system. Hospitality Resource Directory HRD Restaurant Kitchen Cooking catering...
Posted on Apr 15, 2015
    Scholar:
  • 48 Answers
If you are having communication problems with the port on the computer then this can solve it. make sure your pos system is not running or any other background services that monitor the port. Then go into your device manager and go to the properties page for that com port (COM2 for example), hit the device settings tab and change the data bits setting to 7 rather than 8, if this number is different than 8 which is default, just remember what it was in case you need to revert the setting. good luck
Posted on Mar 21, 2009
My 77 Chevy c30 has no power. Jumped started it and drove it home. I turned it off then tried to restart it. No power no lights. nothing. Battery is good. An u help will be appreciated.
If the battery is good you will need to follow flow. Test light is the easiest to use. First hook light to ground and touch pos terminal,lights good next touch pos battery cable end, lights good. Next follow pos cable to starter pos terminal,lights good. Next hook test light to bat pos teminal,touch neg terminal,lights good. Then touch engine block, lights good ground. Next move test light clamp back to ground/neg side and touch alt pos terminal,lights good.if all that tests good, if all good move inside and check for power at ign switch pos term if at any time you dont find power you have wiring issue that needs to be addressed. Let me know what you find. Russ
Mar 29, 2015 | Chevrolet Cars & Trucks
How do you transfer settings and files to a new PC?
Hi Anita,
First and foremost, you should perform a COMPLETE back up of your computer's drive(s) to either CDs, DVDs, Thumb drive(s) or other external drive(s).
Only after you have done this, should you proceed. Microsoft offers an "Easy Transfer Wizard" but there are limitations of what it can do. The most significant of which is the INABILITY to move applications that were previously installed on the Windows XP machine. There is no program I know of that will move installed applications to a new computer and new OS. What it WILL do is move the DATA that was created by these programs; leaving you to reinstall the applications manually again in your new Windows 8 machine. It also moves your photos, music etc - but no applications.
You should download a version of the Wizard that is specific to the OS of your old machine - WinXP (http://www.microsoft.com/en-us/download/details.aspx?id=7349).
Here's a link that details the process: http://www.bleepingcomputer.com/tutorials/transfer-data-from-old-computer-to-windows-8
I hope this helps and good luck!
May 23, 2014 | Microsoft Windows XP Home Edition
Do you know anything about Aloha POS System and touch screen monitors?
Touch screens belong to a new generation of computers that replaced the type keyboards. Usually touch screens are effective to retail transaction requirements. Observe at the retail stores that function resourcesfully with prior prorgamed buttons as acqtion keys. For example, a touch screen transaction system overrides the requirement to typing a request for products either as details. Usually the touch screen device monotor has prior prorgams that allow button pulse responde were an entire prior programs is requestble.
Feb 19, 2011 | Microsoft Retail Management System Point...
What kind of CF card do I need for the Qt 6000?
For IPL loading you must need CF card. This card is available in market with the name of COMPACT FLASH MEMORY Card.It is available from 2 GB to 16 GB Size. The QT-6000 or QT-6600 has capability to format only upto 2 GB size capacity.If more you have to formate through your PC and then use it for Loading and unloading programme in QT-6000
May 09, 2010 | Casio QT 6000 Point of Sale Terminal
Crank pos sensor adjustment on 90 olds cutlass
You have got to space it by feel,so it does not touch either side of the reluctor plates,check the balancer reluctor plates to make sure they are not bent,and the balancer is not coming apart in the rubber part.
Apr 01, 2010 | 1992 Oldsmobile Cutlass Ciera
My one week old usb today said used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive. This happened the last new USB device I bought three weeks ago. Is this a...
Format with this tool.
http://en.kioskea.net/telecharger/download-127-hp-usb-disk-storage-format-tool
NB use server 2 for download. Server1 requires password.
Mar 24, 2010 | PNY USB SmartMedia Reader PC (SFRUSBWB)
Iam working on a compaq pc desktop had windows xp with pen4 iam trying to install a old harddrive i had in a pc that had windows 98 how do i clear all the old thing,s out of the harddrive so i can install...
ok ...the issue is only that it might recognize the operating (win98) system if its installed on it ..if it was just a slave there will be no problems..just attach it ..on the bus and power ...and boot the system ...if you want you may use a partition magic program to format and rename it ...but you can do that with the xp ...by clicking right on the drive in my computer and format from there ... if it doesn't want to format it ..just boot from the installation cd ( xp) and continue like a normal installation until you are at the point where you have to choose the partition to install the program ...choose the new added hard disk and format it ...by deleting and reformat ....but after this just stop the installation and restart the old OS ...but I'm sure that you will be able to format it quick from xp directly ...so , just attach it and boot...click my computer to see if it sees it ..and format
Jul 31, 2009 | Computers & Internet
Javelin LC POS Touch system with no OS
Well you could remove the HDD from the POS, install it into a computer with a CD, remove the HDD currently in the computer, set the POS drive to the Primay Master, install Your OS and any other software (be carefull as to NOT format the POS drive, It may contain important files), remove the drive, reinstall it in the POS system, Put back the drive you removed from the computer.
Apr 13, 2009 | Javelin Systems Inc Javelin LC PC Desktop
Our restaurant has Javelin LCP screens that keep going down
http://www.pointofsuccess.com/demodownload.htm this may help u decide its only a demo but if u like then you can buy full version.
this is a free pos program  ftp://www.gopositive.com/pub/positive/Alpha/PFW4h.exe
quickstart guide  ftp://ftp.gopositive.com/pub/pdf/PFW%20Quick%20Start%20Guide.pdf
just copy and past the links to ur browser
Nov 10, 2007 | Javelin Systems Inc Javelin LC PC Desktop
Ingenico eN-Touch 1000 Digital Pen Logo
459 people viewed this question
Top Ingenico Computers & Internet Experts
David Payne
David Payne
richie46
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
