Question about HP PSC 2175 All-In-One InkJet Printer
Printer cartridge alignment
After changing both print cartridges, The message keeps saying Press Enter to align cartridges. I keep pressing Enter and the message never clears out. Also, sometimes it prints an alignment page, but only in black. I can print things in black only, the color is not working at all. The printer message is always there. How fix this?
  • 7 more comments
  • Anonymous Dec 14, 2007
    I had the same problem. Holding set up and option buttons and then turning off the printer took care of the message. However, now I can print a self test page and the color comes out great but it cancels the print head alignment almost immediatly. I can print in color but it does not print the correct colors in the picture.
  • Anonymous Jun 06, 2008
    Just changed the black #56 cartridge. The message ":press Enter to align cartridges" appears. I have pressed enter for days and the message will not clear. When the alignment page prints it is the first 2 lines and only in black. How can I clear the message and ensure the cartridges are working properly?
  • SarahLem Jun 11, 2008
    The message comes up to align the cartridges. I hit enter and it starts printing but when it is almost done the message says alignment cancelled and the paper comes out. It happens over and over. Why? ANd how do I make it stop?
  • markkluth Jul 04, 2008
    same problem
  • kplus1 Jul 14, 2008
    I have changed the ink cartridges in my printer. The message "Press Center to Align Cartridges" keeps scrooling across the screen of my printer. When I press enter it says it is aligning the cartridges and even prints out the alignment page, but the message keeps scrolling. Also, when I print something in color, the colors do not match.
    Thank you,
    Judy
  • Anonymous Sep 20, 2008
    Same problem. The only difference is that I had several spare cartrigdes, for both color and black. Switched the cartridges, but the problem remained.
    Another aspect of this problem was the printed alignment page seemed to print a bit of something, a bit of color and a bit of black, but did not look "complete".
    Also I ran a "clean cartridges" process, and it printed a page that looked very regular, A sequence of rectangles, followed by several horizontal colored bars.
    So it seems that the printer *can* print... but doesn't.
  • womackme Dec 11, 2008
    I am having the same problem with this printer as mentioned above. I have changed both cartridges repeatedly, but I can't get rid of the scrolling message that says, "Press enter to align cartridges." If I do press enter, it repeats this process over and over again. It does print the test page each time, but the message is still there. I am going to try holding down setup/options and turning off the machine. I sure hope this works. I really love this piece of equipment because it does everything that I need it to do. I sure hope this works!
  • Anonymous Mar 24, 2014
    when i change the numbers for the vertical alignment it just prints the same thing as before with the same numbers
    Device prints but will not print black with color or color with black print.
Another solution...we were having the same issue, but we found out that our black cartrige was out of ink...and when we replaced the cartrige with a new one, the "align cartriges" message when away once we pushed it one final time...we are in good shape now...yes, we are idiots.
Posted on Sep 04, 2008
I had the align cartridges message as well. I pressed the "setup" and "option" buttons, pressed the power button on and off. I also received the button stuck message in several languages. I unplugged the printer for a minute, plugged it back in, turned it on and the printer seems to be working now. Thanks for the help!
Posted on Aug 28, 2009
THANK YOU, THANK YOU, THANK YOU!!! I have had the same problem, tried EVERYTHING, and was ready to buy a new printer! The set-up/options worked...YAY!
Posted on Dec 24, 2008
After spending hours on the HP site I found this and after holding down the 2 buttons everything is fine. Thanks
Posted on Dec 20, 2008
I followed the suggestion of an earlier posting (hold down set-up and options keys at the same time) and it worked! :-)
Posted on Dec 19, 2008
Pressing "setup" and "options" together works for me.
Posted on Aug 07, 2007
Mine did the same thing and i just held setup and options together, the message went away.
Posted on Aug 06, 2007
I tried the suggested solution and it has made things even worse. Now my printer display tells me in every language under the sun that my buttons are stuck and I must release them! I can't turn it on or off (have tried turning off and back on at mains but it just comes back up with the same buttons stuck message now when it comes back on). I am very frustrated - please can someone help?
Posted on May 24, 2007
Hold "setup + options" at same time while turning off printer and back on while holding "setup + options"
Posted on Apr 04, 2007
I'm having the same problem with my printer. Please let me know once you get an answer to how this can be repaired. Carmen
Posted on Dec 30, 2006
I tried the method of holding down the setup and options buttons while turning it off and then turning it back on but I too had to read a few languages saying the button was stuck. I then held down cancel and restarted the printer. When the align cartridge message appeared again I pushed the setup and options buttons again (without turning it off) and the message went away.
Thanks for the help. Merry Christmas everyone!!
Posted on Dec 17, 2008
2 Suggested Answers
  • 8 Answers
SOURCE: Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Posted on Nov 02, 2008
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Printer hp 2210 always says Press Enter to Align Cartridges. When I press enter it aligns and than says the same thing. When I try to print it won't print from the email or when I'm on line. When I press...
You press Enter , but the error message does not go away ? You have to bypass the cartridge alignment -
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
Jun 15, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
My hp psc 2175 all-in-one keeps giving me the message "press enter to align cartridges." When I do that it says" printing align cartrigdes page" then it says "alignment cancelled" and then goes back t
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Try the following button sequence on the front panel of the printer :
Press and hold the Setup, button, and then press Options (or Copy Options).
Oct 25, 2008 | HP PSC 950 All-In-One InkJet Printer
My printer wont print it keeps saying press enter to alein cartridge
I just noticed in the link to your forum item that additional text appears that does not appear in the item itself. It looks like you are getting a message telling you to press Enter to align your print carriage. This is a common step after you replace an ink cartridge. According to HP.com, here's what you are supposed to do:
"A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete".
The link to those instructions is as follows:
Replace the Print Cartridge
Just follow the instructions I posted above in italics and you should be good to go. Good luck.
Oct 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
805 people viewed this question
Clive
Clive
