Question about Microwave Ovens
REPLACING FUSE IN WHIRLPOOL MICROWAVE
REPLACING FUSE - HOW TO GET TO IT?
  • CAREDITH1 Nov 04, 2008
    WHIRLPOOL MH1170XSQ-0
  • Anonymous Mar 16, 2009
    where is fuse located
  • Microwave Ovens Master
  • 9,011 Answers
It's hard to tell from the exploded views, but it appears to be on the floor of the microwave behind the control panel.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If the fuse is not the culprit, also check the two thermostats - one on the magnetron and one on the top of the oven chassis.
The mini manual / tech sheet will show you where they are and how to test them.
To check the oven thermostat, you will need to remove the oven from the wall. You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 08, 2008
2 Suggested Answers
MicrowaveSvc
  • 9011 Answers
SOURCE: NTC cover message after replacing fuse
The "negative temperature coeffecient" (NTC) thermistor was left unplugged after reassembly or it is defective.
It is the hood thermistor, and should be plugged into connector P4 on the circuit board.
I think it should be at the bottom of the board, on a little tongue-like protrusion, as shown in the attached photo.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Aug 17, 2009
Testimonial: "Thanks, using your photo as a reference, pushed NTC in firmly and have no other problems. Thanks again."
I have a Whirlpool Microwave! It kept saying open/close door. Than everything went out! Nothing works! Is there a fuse or reset button?
Please post the model number of the microwave for more detailed assistance. Sounds like a fuse in the microwave shorted out. Most likely caused by a bad door switch. Recommend replacing all door switches that are there and then replace fuse.
Jan 25, 2017 | Whirlpool Microwave Ovens
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
How come my over the range microwave does not turn on at all??
Check internal fuse. If it's ok, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. Diagnostics and repair might be quite complicates so better you take it to a repair service. You have some interesting Youtube video tutorials to repair a microwave
How to Fix Microwave Oven Simple Fuse Replacement
Replacing Microwave Fuse Pt1 of 3
Microwave No Power Repair
Microwave Not Turning On Fuse Testing Microwave Troubleshooting Repair
Sep 23, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave oven no power
The main fuse is probably blown.
When replacing, try to determine the cause.
if it has a bad door switch, then the monitor/short switch also must be replaced. On an inverter, replace the power relay as well.
If the fuse holder is not holding the fuse securely, then it will heat and blow.
A failing component in the high voltage circuit can also cause the problem.
Apr 04, 2014 | Whirlpool GH7208XR Convection / Microwave...
Changed light bulb and still don't work
Did you check the fuse ? this may need replacing also
Apr 03, 2014 | Whirlpool MH1141XM Microwave Oven
Replacing a fuse
do they look like allen screws or more like stars(torx)?
Dec 31, 2011 | Whirlpool MH2155XP Microwave Oven
Replacing a fuse
Try sears dept. stores in the hardware
Jul 09, 2010 | Whirlpool GH5176XPS Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New Microwave just went out no power
I had the same problem and fixed it with the help of others in this forum. There's a 250V 4A slow-blow fuse in a holder in one of the wires running from the main circuit breaker.  Just behind the upper end of the control panel.  Replacing said fuse got me running again.
Jun 25, 2007 | Whirlpool MH3184XP Microwave Oven
Microwave Ovens Logo
3,629 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
