Question about Gateway Computers & Internet
Trying to find a place to get replaceable battery for my laop top
    Scholar:
  • 65 Answers
Http://www.batteries.com/g_index.asp?gclid=CL7HmJHJ3JYCFQkiagodsh4v2Q
Go here, if the laptop is new within the last 6 to 8 years, they will Either have it,or know who to go through to replace it
Posted on Nov 04, 2008
INSTALL DRIVER RECOVERY CD FOR HP DV4 1555DX
i went back to factory on my hp laop top g 6 three times i keep getting windows 9 i should have windows 7 on it
Nov 23, 2013 | HP Pavilion dv4000 Notebook
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
Polar express lantern stoped working how do i get the battery changed
It's possible but you have to use a razor saw and cut the top off the lantern. Go around the top and cut only through the plastic. Don't try to saw a single cut all the way through the whole top at once. You can then replace the 2 CR1220 batteries inside. I added some tabs to the top with scrap plastic and drilled holes so the handle would hold everything in place.
Dec 02, 2012 | Toys
I have a hp pavilion dv2000 laop top I have windows 7 Some how I got a virus on my computer and it deleted my cd/dvd off my computer i cant find it no where not in divice manger how can i get my cd/dvd...
If you had a virus and you want every thing back to normal and CLEAN RE-INSTALL WINDOWS or use the recover CD, just don't forget to backup all your data first...
Apr 09, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
When I turn on the Saturn and place a game in the drive. and close the door. It gives me a message drive door open.
Sounds like the CD tray is not closing. Try opening up your Saturn and checking on the top-left corner, next to the part you plug your power cable into. There is a small switch that the CD cover presses on, try holding it down while you turn it on with a game in it and the top half of the case off. The game should spin and play. If you tape it down, it should work fine. If that didn't work, try replacing the battery. The battery you need is called a CR-2032. You can get this at you local CVS, Wal-Mart, or any place that sells watch batteries. After you do that, simply pop off the back panel, take out the CR-2032 battery, and pop in the new CR-2032 battery and then it should work. If that worked, congrats for your Sega Saturn being back in action.!
Aug 11, 2010 | Sega Saturn Console
What battery do I need for this? It says 1154 but
Cgregor, that was your answer. Try actually being grateful for the help and voting.
Mar 12, 2010 | Sportline 345 Electronic Pedometer
Had not used our mouse in quite awhile, put in new battery but still is not working
If its the 3000 ... you need to snap the battery compartment in correctly to get the battery to work.
Replace the battery. When you reclose the battery compartment you just snap it in place but be carefull.. even though its easier to insert the top and then slide the bottom down in DO THE REVERSE... insert the bottom prong allllll the way in and then snap the top forward and into pace. In order for the battery to work the top needs to be firmly in place and I've found that snapping it in in the aforementioned way is the only way to make sure its snug n stuff.
Hope that helps. I've had this mouse for five years and love it but alllways forget that issue in replacing the battery and inevitably spend fifteen minutes scratchin ma head everytime the battery needs replacement.
Feb 25, 2010 | Microsoft Wireless Notebook Optical Mouse...
As i put the battery in its place in the lab top, The fan start running without pressing the ON/OFF switch? lap top not working, only battery led flicking? what i should do?
make sure the laptop is fully powered off first by holding down the power button for about 5 seconds, then insert the battery and see if theres any change.
also try using just the power adapter without the battery and see if it starts.
Apr 26, 2009 | HP Compaq nx5000 Notebook
The battery charger problems
Try those hereunder mentioned.
1. Clean the battery charger pin & battery charging point too. If the red light still blinking then replace your battery. Your battery life is finished then.
For confirmation try to charge your battery from others people charger or ask some same battery and fixit in in your charging place. You can short out then which one have problem.
Thanks & waiting for your feedback.
May 29, 2008 | Olympus Camedia D-590 / C-470 Digital...
Installing wep ssid on smc wireless adapter
Phone number 133 933 found here: http://my.bigpond.com/help/contactus/techsupport/default.jsp
Jul 29, 2007 | NetGear USB 2.0 108MBPS Adapter 802.11...
Computers & Internet Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
