Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
The electrical panel does not light up
The oven works perfect. but the light on the control screen does not light up. I can barly see it at night when it is dark.
  • 3 more comments
  • MARELIZ Nov 14, 2007
    The digital panel stopped working and does not light up. We changed the panel thinking it would solve the problem, only to realize that we wasted our money and the problem continues. The double ovens work perfectly fine, but I have to guess the temperature since the panel does not light up.
  • john lucier Nov 22, 2007
    Jenn-air display is dark, you can see it at night. everthing else works fine
    dark display, faintly visible when room is dark. Backlight?
  • mckinnonw Mar 21, 2008
    I have had two ww30430p ovens and both had this problem at about 36-48 months. In both cases Jenn-Air replaced the part for no cost, but I had to pay a technician to diagnose it and to install it. They would not take my word despite my having taken the oven apart and identified the problem and the part number and the solution.
    Overall, not thrilled with Jenn-Air
  • sandyc1 May 08, 2008
    The oven control works but can not see the temperature and clock. I called coast appliance store in san diego and they said the problem could be either switch membrane or the clock itself. Each of them cost about $200 and it's a trial and error approach. Aparently these parts are special order and can not be returned if they don't work!!
This is a HEAT issue, not electrical. It is a design problem. The HEAT is "burning" the display panel in the older models. In the new models, Jenn-Air has put a cooling fan underneath the display panel.
Posted on May 03, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
There is the led display unit and the power unit both of which cost about $150. I don't know which one to replace.
Posted on Dec 01, 2007
  • 175 Answers
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Posted on Oct 06, 2006
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
Top oven appears to have no power going to it.
Contact an electrician and or the power company.
I believe you have lost the neutral/ground in your power service.
Feb 21, 2009 | Maytag CWE5800A Electric Double Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
May 15, 2008 | Whirlpool RBD275PD Electric Double Oven
Oven Light won't shut off
Amazing, I had the same problem, was told the same thing, even quoted the same amount!   There must be a playbook with stupid answers by repair people.  Anyhow, here is how I unlocked my oven:  "Press and hold the 'Lock' button for 3 seconds then let go and it should unlock in about a minute."  Hope this works for you. Don
Nov 13, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Ge wall oven display says F7
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at hutchipop@yahoo.com.
May 29, 2007 | GE JKP30WMWW 27" Built-in Single Electric...
Neff B1641 Switched my oven on the other night it made a noise like a fuse blowing and went dead no lights no controls whatsoever i checked the power and i traced it all the way to the control panel...
check you have power at the clock - the clock terminals not the relay. if not, there is a cut-out stat in the back. check this is still ok. if there is power at the clock then the clock itself may be faulty. you can bypass the clock by joining the terminals to the clock relay and get the oven going this way. another common source of problems is the terminal block where mains comes in and is distributed. these terminal blocks often burn out.
May 04, 2007 | Neff B1641 Single circotherm super...
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
295 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
