Krups 239 Power X Plus Work Top Blender
Problem for Krups 239 Power X Plus Work Top Blender
Krups blender drive gear
By eyizek on Nov 04, 2008
How do I remove the blender drive gear from my Krups blender model 239? Thanks.
Ed
Same Problem
Dec 08, 2008
-   i'm ordering the grey rubber drive gear part but need to pull off the worn one. can't get it off! -   jesfamart
Best Solution
posted on Feb 01, 2009
Helpful)
memerick
Rank: Apprentice
Rating: 85%, 1 votes
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Was this helpful?
Yes
No
Popular Solutions for Krups 239 Power X Plus Work
Questions and Unsolved Problems for Krups 239 Power X Plus Work
Do you recommend Krups 239 Power X Plus Work Top Blender?
Answer
Answer
Nothing when power on.
Answer
Krups 239 - Motor works but it seems to increase and decrease in power when it is on.
Answer
Krups Model 239 Blender runs fine but blade cavitates when 'blending' almost anything - soup, ice... (More)
Answer
The drive gear (coupler?), okay "thingie" that turns the blade assembly on my Krups 239... (More)
Answer
The motor works, but can't rotate the blade when the unit is empty (or full). I took it apart and it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Krups 239 Power X Plus Work...:
Top Blender Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
