Question about Refrigerators
KSRS27QGWH - Frequent defrosting needed for ice delivery system
In the summer, I have to defrost my KitchenAid ice maker delivery system every 7-10 days, or it will only spit out ice chips because of the frost buildup. I have gotten very proficient at defrosting through repetition.
The freezer gasket appears to be fine and the chute door/flapper still fits flush against the bottom of the chute. The problem seems to be a little worse every summer. Suggestions?
  • nabberva Nov 04, 2008
    Which door?? This is my first experience and I hope it's not typical. This person took no time and probably less thought to answer this AND it sound like they stopped in the middle of a sentence.
    NOT HAPPY YET.
    Genius:
  • 1,550 Answers
The defrost thermostat is failing in your unit . You need to replace it .
How old is your refrigerator ?
Posted on Nov 04, 2008
    Scholar:
  • 155 Answers
Get it checked to some proper technician as its the problem of ventilations as if somewhere air is getting leaked or somewhere it is getting blocked.mostly the ventilations area r below the frost trays or any of the doors are not getting properly closed so giving such problems.
thanks.
  • 3,037 Answers
You probably have a bad seal on the with the door. Try replacing that rubber strip and see if the problem still continues, I'm betting that moisture is leaking through more and more because of the age
  • Benjamin Patri
    Benjamin Patri Nov 05, 2008
    The main outer door, I'm sorry if my initial solution was short and confusing but the rubber seal that is around the main doors of the unit, if broken can let in moisture which then condenses and forms ice and as the seal gets worse, the ice build up will become worse. Let me know if you are in any way confused or have any questions about what I am talking about or how to go about working on this
Why do we hear a water draining noise on kitchenaid superba?
Hello Mari;
My name is Peter. I am a retired field service refrigeration technician.
You have a condensate drain in the back bottom of your freezer for when you go through a self defrost mode. The defrost mode is so gradual there is not enough water flow to make a noise.
What you are hearing is your ice maker filling with water. Your ice maker will fill 8-10 times within a 24 hour period.
Dec 23, 2014 | KitchenAid Refrigerators
KITCHENAID ICE MAKER STOPPED WORKING LED BLINKS WHEN FREEZER DOOR IS OPEN
Try firs unplugging power for 510 minutes, see if it reset.
Oct 10, 2008 | KitchenAid Refrigerators
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
I have a drip coming from my kitchenaid ice maker which flows into the water/ ice dispenser tray then down the front of the door. The refrigerator was purchased in 2005 and the problem started last...
It's either the ice tray leaking , In witch case you should replace it , Or the water inlet valve is is sticking open and overfilling the tray, in this case you will need to replace the valve behind the refrigerator where the hose connects. Good luck
May 18, 2011 | Refrigerators
We have a Kenmore Elite side by side refrigerator, model no. 53209, purchased in 2003. Recently the drain hole/hose to the drip pan beneath the freezer compartment has been freezing up, apparently during...
Good day,
It's become a common problem on newer machines with less frequent defrost cycles and for a shorter period of time.
The following clip, as you scroll down will see the most exotic procedure. You may not have to go that far.
Using a length of #14 bare copper wire, and wrapping it around the heater and inserting it into the drain hole will usually work. You will need to remove the heater to perform this process properly, and I prefer to wrap the copper close together, each wrap touching the last one. Your call.
kitchenaid-top-mount-refrigerators/" spwrap?>kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Your machine is a product of Whirlpool which makes many brands, all of them with the same basic system.
Oct 19, 2010 | Kenmore Refrigerators
My freezer compartment is full of ice and frost on kitchenaid ktra22emss
if a no frost frig is frosted then the defrost system has failed . look at the heater / and defrost terminator . and the aditive defrost control as any one of these will cause the problem. . on some models the drain in the freezer is pluged and needs cleaning . this will cause ice build up on bottom of freezer .. ( clean drain with hot water & turkey baster ....hope this helps mm
Oct 09, 2010 | KitchenAid KTRA22EMSS Top Freezer...
I own a KitchenAid Side-by-Side Refrigerator Model No. KSRG25FTSS01. It was installed April 2009. Since then, the drain pan has overflowed twice. The dealership repair crew cannot find the problem. The...
no pan check the door seals make sure they are sealing good not letting air in . when you have high defrost water there is air getting in somewhere or the ice maker is leaking letting water in the freezer
Oct 03, 2010 | KitchenAid Refrigerators
KitchenAid KSCS25INSS01 ice maker intermittent failure. It periodically stops making ice for days. I noticed it occurs when there is heavy use on the RO unit that supplies it. The drop in water pressure...
no you dont want to go there !
there is a chance that your water valve is dripping and water are in the line...also there is a heating kit for your fridg that prevent that ask your local tech.
Dec 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
I have a Kitchen Aid side by side KSRS25IL. The ice maker after
Sounds like you need to defrost.
if you can move everything out unplug it ,turn it off w/ doors open,you can put pans of hot water in the freezer to speed up the process 12 to 24 hrs this will free up any clogged tubes.After its completely defrosted Only turn it up to 4 or 5. Good luck.
Len West
Feb 27, 2009 | KitchenAid KSRS25IL Side by Side...
Rubber door gaskets very warm to touch, ice cream soft, ice ok
the icemaker will work until the frezer gets to 17 then it will quit sound like a defrost issue defrost heater defrost thermastat or defrost timer need to get it fixed sooooooon you dont want to loose food at the price we have to pay
May 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
