Question about Zanussi WJD1457W Front Load Washer / Dryer
Door making clicking noise when trying to star wash,error 40 comes up.
  • 139 Answers
E20 is a pump error code either the pump is not connected or there is a problem with it sendind back a signal to the control board that there is fault there. however as your saying the door just wont click shut that has happend to me before and it has turned out to be the main control borad. try the pump
Posted on Oct 10, 2006
Model NFW7200TW Washer wont fill with water
Are you sure you have both hot and cold water connected? Try turning the water valve on, if you don't have hot water make sure you choose cold cycle. That's the first place I'd start.
Dec 02, 2015 | Amana Washing Machines
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
Zanussi washing machine zwf14581w . err e40
Hi.
Error 40 means : "Door Error"
When you get error 40 it is usually because of a defective door interlock.
Try disconnecting power for five minutes. If the error comes back the parts to be tested are door interlock, wiring or main PCB. The defective part must be replaced. Parts and quote on repair can be obtained contacting Zanussi customer service at the number listed on the owners manual.
Regards.
Ginko
Aug 20, 2011 | Zanussi W1042W Front Load Washer
E 40 code error. Just keeps clicking then error message?
e40 is the alarm if machine started with door open. door lock may be faulty or connections/ wiring to it. possible for door ******/handle to come mis aligned in the door you have to split the door to check the handle shaft has not come out. watch where the springs go. the clicking is the electronic trying to lock the door.
Aug 03, 2010 | Zanussi ZWF1440 Front Load Washer
E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
Display say F30, It is not finishing the wash, lots of clicking noises...any suggestions
Sounds like a door locking error. Clean around the door with soap and water. (if the noise comes from the front. Check the drain if noise is from the back( may be crimped /twisted). Here is your manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Aug 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer has an F dl problem?
Fdl is a code that indicates a door lock error. The clicking sound that you hear is most likely the door lock. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet Sport not running it makes clicks and it grinds
    A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
    It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Duet Washing Machine model ghw9100lw1 FH ERROR CODE
    you should here a humming noise, just before water comes in .do you?close eire let me know.
    Dec 07, 2007 | Whirlpool Laundry 27'' Duet Ultra Capacity...
    Zanussi WJD1457W Front Load Washer / Dryer Logo
    159 people viewed this question
    Top Zanussi Washing Machines Experts
    jimorris77
    shaun taylor
    Marvin
    Marvin
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
