Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
Attachment problem Runs Great but when trying to change attachments the last one came off just fine but when I went to attach the trimmer, as well as the others, they would not slide all the way in. When I give it the gas you can see the drive shaft spin; however if you tilt the engine back & forth you hear a "clop" type sound. Thanks Bosssmann
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Poulan Pro Pp125 25cc Gas Straight Shaft
Here is my Tip(s) on this problem:
Posted on Aug 14, 2011
  • 2239 Answers
SOURCE: no power when attachment is on
If the carb is set too lean it will run and high speed, however once you put load on the engine there will not be enough fuel in reserve to icrease the power, try richen the mixture on the H screw with the attachment on.
Posted on Jul 08, 2012
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
No power when attachment is on
Jul 07, 2012 | Poulan Garden
Trimmer runs but the head wont turn
It may be that the drive shaft is broken, or not engaged to the engine. Make sure the trimmer attachment is locked all the way onto the shaft coming from the engine. If it still doesn't work, check by seeing if any of the other attachments work when you put them on. If they do, you know the drive shaft in the trimmer attachment is probably broken.
Aug 17, 2011 | Craftsman Convertible 25cc. Gas Line...
too much drag on the edger, try putting some oil or lubricant spray where the edger spins on the attachment.
May 03, 2010 | Garden
Trimmer runs good but does not cut grass
I have had a similar problem with an edging attachment. The socket that fit onto the shaft was worn, and the shaft would just spin, creating a lot of heat right there, but very little movement, and it would completely stall when you tried to use it implement, even though the moter still ran just fine. The cure, I'm sorry to say, was to replace the implement.
Best regards, --W/D--
Aug 15, 2009 | Craftsman Convertible 25cc. Gas Line...
Engine runs great, no power at head, drive shafts not broken.
The drive shaft is not seated into position properly or the shaft has broken.
Have you had the shaft off recently? If so, take the shaft off again and try to seat the shaft as you gently pull on the rope. If you need further assistance, just let me know.
Jun 15, 2009 | Troy Bilt Tb70ss Gas Trimmer
When I add an attachment to my Craftsmen trimmer, they won't spin
When you add the attachments the drive shaft must be aligned perfectly and the connecting tubes fully inserted. Otherwise they will not drive. The drive shavt has 4 flat faces on it and the recepticle for the drive shaft also has 4 faces on it. If they are not mated correctly nothing will work. The drive tube must be fully inserted...... and aligned.
Jun 12, 2009 | Craftsman Convertible 25cc. Gas Line...
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
141 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
