GOT ACER POWER T600,LOOKING TO UPGRADE MEMORY.SPECS SAY PC3200,400MHZ,IN COMPUTER PC2700,333MHZ.ARE THEY BOTH COMPATABLE
    Genius:
  • 1,605 Answers
PC 2700, 333 MHz is the minimum and the upgrade is pc3200 400Mhz
Acer usuanlly give you the lower grade meories. they figure you goin gto upgrade anyway.
the other manfacture give you what they say in the spec. sheet.
Posted on Nov 04, 2008
I want a dual core processor upgrade
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireX1200/AspireX1200sp2.shtml The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at: http://www.filehippo.com/download_speccy/.
Jan 12, 2013 | Acer Aspire Computers & Internet
I tried to upgrade the memory from 1 GB to 2 GB, but after that the computer's screen won't turn on, and i can hear three long beeps and two short ones
The beeps indicate memory issue.
Acer Aspire One Notebook supports upto 1.5GB of memory, so if you try to install 2GB it will not work.
Size 1.0 GB / 1.5 GB (max)
Technology DDR2 SDRAM - 533.0 MHz
Form Factor SO DIMM 200-pin
You can also Click Here to check the specs on the Cnet website.
Regards,
Shrey
May 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I just purchased a new Acer Aspire AS7741G-6426 Laptop. I want to upgrade from 4GB memory to 8GB memory. I need to know what brand and specs to look for.
Just refer to your laptop manual. If your manual got lost go to the  acer website and find your product and download the manual.http://www.acer.com.ph/ac/en/PH/content/home .
when upgrading your memory you have to consider the following:
the processor: if your processor has 4gb compatibility mem you can upgrade upto 6 to 8gb.
                      take note that you must not exceed to 8gb or else your processor might be damage.
                      get the processor speed: example core 2 i3 processor, 1.0GHZ-the frequency.
the Memory or RAM(random access memory): get ther specification: example is DDR1 or DDR3
        PC133 or PC 400. Thats all.
Note: your current memory must have the same memory module(example PC400,PC 133)  or else it wont work.if your going to upgrade your current 4gb PC400 you have to add 4gb memory in PC400 module also.
May 01, 2011 | Computers & Internet
How can increes speed of computer.
you are using Thinkpad T30 2366 and if it has a low RAM (memory) you can upgrade that. I check your computer specs online and what I saw is this P4-M 1.8 GHz but unable to verify if it has 256mb RAM. If it does you can upgrade that to 512mb.
you can look on this website { http://www.edgetechcorp.com/memory/upgrade.asp?cid=27556 } just to check the compatible RAM for your computer.
Mar 26, 2010 | IBM ThinkPad T30 2366 Notebook
Upgraded RAM on Acer T135 with 1 GB module. Computer will not turn on, just beeps. All connections are fine. What do I need to do to get computer to recognize the RAM
You either installed the wrong kind, the wrong brand, or to much memory.
So if you did one of these, there is nothing you can do to make it work.
First you should remove it. If you need more help, you need to post
your serial #, because this is the only way the Acer website will allow someone to look at the system spec's of the machine.
If you post back, also post the exact memory you installed,it will look like this,
Example- Crucial-2g-240pin- ddr3 1333(pc3 10600)
Feb 14, 2010 | Acer Aspire T135 PC Desktop
How to change DDR in Acer 5310
You mean how to change or upgrade your memory card in your acer computer? If thats what you mean, I suggest you bring your computer in to computer shop and ask them for a compatible memory upgrade for this computer..:-)
Hope this could help you..Thanks..
Dec 23, 2009 | Intel Motherboard
Acer aspire one no video
Check the specs of your laptop regarding the memory. If the new memory that you installed is compatible with your laptop or not.
Example: If your laptop handles like DDR 200 and you did installed DDR 300 or above with the limit or specs of your laptop, then it will coz some harm on your computer.
Try to review and check the specs of your laptop right away so that you can refund or exchange your memory into a compatible one. Thank you.
Oct 07, 2009 | Acer Aspire One PC Notebook
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
Acer Aspire Memory problem
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Apr 11, 2017 | Acer Aspire T650 (AST650UC3601) PC Desktop
Memory upgrade for laptop
Older laptops can be VERY fussy about the memory ... you have to have the exact same 'speed' .. I had a similar problem after trying to upgrade an old machine that took slow memory (PC100) with a FASTER (PC133) module ...
NB> Some VERY old machines would not take 'double sided' modules ... check the manufacturers specs ..
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
