Question about Hitachi 43UWX10B 43" Rear Projection Television
Convergience The convergience is slightly off on the entire screen but especially bad at the top left. Too bad to adjust. There is some defect somewhere. Please help. If I need a new part, which part? I have a schematic. Cancun Kid
  • 139 Answers
Hey Cancun,Ill be able to Answer this on Tech Support my Screename ttech
Posted on Jul 20, 2007
I have a model 60PP9202 60" Phillips projection TV that has color convergience problems. It started a few years ago when the TV wouldn't turn on at all. After unplugging it for several hours, it...
Below is a link I have included. This is a site I use to repair parts in projection tvs. The kit includes detailed instructions on how to repair it yourself. If this told you something you did not know rate this solution as very helpful as I do this here for free.
ALSO, if you have questions reply to this posting and I will assist you--I am here to help.
http://www.tvrepairkits.com/xcart/product.php?productid=23609&cat=3647&page=1
Jan 05, 2011 | Philips 60PP9202 60" Rear Projection...
JVC av-56pw30 Picture Adjustment
Sounds like you have a convergence problem and the set will require repair. This repair will run somewhere around $400 if you have a good company complete the repair for you.
If you are interested in doing this repair yourself you will need to be able to use a meter and solder VERY well.
If you have more questions please email me.
Thank you,
Tim Nolan
Experttv@comcast.net
Oct 11, 2008 | Televison & Video
I want to fix convergience myself....what or where do i go?
Go to the following link and leave a email with the model number of your set and what ist doing and they will respond quickly with the info you need they have any part you would need for your RCA and they give free tech support with their parts.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bent picture
Not sure if you fixed your problem already. But the answer is a color convergence problem. You can try adjusting manually via the remote and if that doesn't work it is most likely the two main IC chips that control the color convergeance. It is also possible that not only the IC chips have gone bad but also there are a couple of resistors that usually burn out with the ICs as well. They will need to be replaced. This isn't something that I would attempt on your own. Typically a TV technician will charge between 300 and 400 to fix at your house.
Mar 15, 2008 | Philips 60PP9363 60" Rear Projection...
2 1/2 years new Samsung HC-P4752W from Costco, Canada
Samsung makes a great product and has one of the best pictures out there. I have had mine for a couple of years and only experience a slight convergience issue on left and right sides of the screen after twenty minutes of run time. I am currently trying to figure out how to fix it.
Jan 26, 2008 | Samsung HC-P4752W 47" Rear Projection...
BLOTCHES ON SCREEN
This may not be the problem, but the following service bulletin may be of interest:
Last Update: 1/25/2006
Document Reference/Event ID: E30094243
Model: KDSR50XBR1, KDSR60XBR1
Subject: Picture might have a slight Greenish tint.
SYMPTOMS
Under certain conditions (especially cold/ first power ON), white areas of the picture may take on a slightly greenish tint after power on until internal temperature stabilization is achieved. Typically, this disappears after approximately 10 minutes operating time, however, in certain cases (i.e. colder conditions) the set will continue to fine tune the picture longer that 10 minutes. This is in order to create optimum picture performance under nominal viewing conditions.
This is not a defect but a characteristic of the LCD panels. Be assured that the time it takes to disappear will neither lengthen nor reduce over time.
If the condition improves but reduction in effect is desired, there are customer adjustments that can minimize this condition. Please demonstrate these adjustments with the customer, to determine if these settings are acceptable. (User adjustments are supplied in Solution A)
In cases where no Uniformity improvement is achieved (after 30 minutes power on time) proceed to Solution B; Optical block
Note:
Please be aware that all Optical Blocks exhibit warm-up behavior.
Replacing an Optical Block will not eliminate or significantly reduce the time below 10 minutes.
RESOLUTION
CAUSE:
Internal temperature stabilization needed.
Solution A)
You may reduce this effect by changing some user settings as follows:
(1) Change the Color Temperature setting to Cool - (refer to page 81-82 of the instruction manual). If further reduction is desired proceed to step 2.
(2) Slightly Reduce the Green bias (only available in PRO Picture mode under Advanced video settings), then select white balance Adjustment - (refer to page 81 of the instruction manual). Example:
a. Menu, Video, Picture Mode, Pro Mode
b. Menu, Video, Advance Video, White Balance, G-Bias (Reduce several steps)
Solution B)
Replace Optical block after gaining approval from Sony Tech. line.
Jan 23, 2008 | Sony KDS-R50XBR1 50" HDTV
Sony 51inch tv blue screen appears
could be a blu tuibe but also i've seen many bad sony CRT Drive bds(the circuit board connected to the neck of the tube). You won't find really any place cheaper than the next if your a consumer. just try partstore.com Oh, and forget about sony paying for it 4 years is way out of warranty.
Apr 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Hitachi Standard T.V.
Some of the problem could be a weak or damaged picture tube - especially if it encountered rough handling in the move. Other possibilities are bad capacitors in the power supply and deflection circuits which are common with this aged set. No adjustments come to mind that could permanently fix these symptoms.
Feb 11, 2007 | Hitachi 27UX01B 27" TV
Toshiba 32AF41 Power up Problem and Green Screen
My first inclination would be to check the picture tube, especially if the set is over 7 years old. If it is not that, then anything from bad solder connections to capacitors or a defective IC could be the cause. If it's over 10 years old, replace it. No use flogging a dead horse.
Jan 13, 2007 | Toshiba 32AF41 32" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
89 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
