Question about Tomtom ONE 3rd Edition GPS
Spinning display The display will start spinning. It's almost like it loses it's position. It then tries and recalculates but it doesn't make any sense. Eventually, it 'finds itself' and gets back on track. This happens sporadically and it doesn't matter if we are near a traffic light or near near wires, etc. I sent the description to TomTom support and I updated the application as directed. When I used it again, same problem. Not all the time, it's sporadic and I can't find a common thread when it happens.
  • 409 Answers
Itcould be that the windscreen on your car has a heating element or some coating that is causing the receiver to have poor reception. You could try and external ariel (they are available as an option)
Posted on Nov 04, 2008
Avoid on route greyed out
I will keep telling you to turn around to start with but then recalculate route
Jan 31, 2014 | Tomtom GPS
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
When i take off from a starting position it feels like the back wheels are spinning, losing traction and power it doesn't happen all the time
You are a front wheel drive all traction is in the front,either you are overeving which is a transmission slip,if you say you loose power when accelerating you are describing a plug air filter and even a plug catalytic
Mar 06, 2012 | 1989 Mazda 323
My tom tom 750 live is very slow to recalculate route and is slow to load a route and some times loses gps signal
Jul 04, 2011 | GPS
While traveling to Nova Scotia last week, my Garmin Street Pilot c530 was telling that i was on an unpaved road, but i was on route 2 in New brunswick Canada
Don't believe everything you see on a GPS. Garmin does not update their maps as they should; I found this even after I purchased their map update. I drove 48 states in a big rig, over many new roads not found or shown on the Garmin maps. My streetpilot usually went into a hiccup mode, recalculating -- recalculating -- recalculating. All the while, it tried to get me to detour on whatever spurious local roads happened to show up along the way.
Aug 07, 2009 | Garmin StreetPilot c530 GPS Receiver
Magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Reset oil change indicator 2008 mercedes benz E350
With the key in position 1, hit the odometer reset button on the left on the cluster 3 times in a row. The cluster should beep once. scroll through the multifunction display with the page buttons until the display shows the onboard voltage screen. It will say something like "UB: 12.2 V" scroll threw this menu with with the up/down until you reach the "service menu" page. scroll down to "confirmation" press +, confirm full service with +. Wait till it says service confirmed. cycle the key off and then back on to position 2. Scroll to the normal service menu where it normally says how many days or miles till next service. If the service was reset correctly, it will say "service display not possible" for a few minutes while it recalculates. You must cycle the key off and back on before it will back out of the onboard diagnostic mode. If you dont back out, the esp/abs/bas lights will illuminate when the car is started
Dec 03, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Nuvi not working properly
I had the same problem until i realized it was I myself who messed things up. What you probably did was change the settings to "pedestrian" and forgot to change it back to driving. When you set your system to pedestrian, it does not recalculate a new driving route because it assumes you can just walk there. (You can walk in any direction very easily, so no need to recalculate).
If your garmin is also sending you down a one way street, thats another tip you are on the pedestrian setting. (If your walking, you can walk down one way streets).
I am not sure however, what other types of weird things happen when you are on the bicycle setting, i havn't tried it yet. But i am positive you are trying to use your garmin on pedestrian, put it back on automobile. Let me know if it works, thx
Jun 18, 2008 | Garmin Nuvi 350 Car GPS Receiver
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Tomtom ONE 3rd Edition GPS Logo
44 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
