Question about Tomtom GPS
My son in Law gave me a TomTomOne and I would like to update the maps. I plugged it in to the computer but no results. Help!
I woke up and turned on the Tomtom. Problem solved. ALC
Posted on Nov 06, 2008
How do i update my gps
A GPS will help find the shortest and fastest routes to a particular destination. When the maps are out of date, the GPS may not be able to find the best route. A GPS should be updated at least once per year. Some GPS manufacturers will allow the user to download free updated maps; however, many manufacturers require the user to purchase updated maps. Updating a GPS map isn't complicated, and will take about 2 hours to install.
1.Turn on the GPS and plug the USB cable into the USB slot located on the GPS.
2.Plug the other end of the USB cable into the USB slot on the computer.
3.Insert the map update DVD into the computer. If you have a map download, locate and open the file on the computer.
4.Click on Update Firmware located on the main menu. Click "OK" when the firmware is finished updating.
5.Unplug the USB from the computer and turn off the GPS. This will allow the firmware to reset on the GPS. Turn the GPS back on and select the language and time.
6.Reconnect the USB to the computer and click on "Update Map," then click on "Load Maps."
7.Connect to the Internet by clicking on the activation link. This will display the activation number. Find the serial number located on the back of the DVD. If you downloaded the update, a serial number was provided. Enter the serial number and activation code into the update program to continue updating.
8.Close the program after it has completed the update, and unplug the USB from the computer and the GPS. Turn off the GPS to finish the update.
I hope you find it very helpful. Thank you for using fixya.
Aug 20, 2011 | GPS
Sometimes tomtomone got lost on the road.
  • If you Tomtom GPS is continually getting lost ad reconfiguring then it is time to update your map here
http://www.tomtom.com/page/mapupdateservice
  • Once you update the map you will not have this problem anymore.
Regards, Tony
Apr 26, 2011 | Tomtom ONE 3rd Edition GPS
Cannot log on
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Apr 22, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Cannot repair vista ultimate!
hmmm... try turning it on then while it's booting windows forece the computer off.
then turn it on again and select launch startup repair. you can try everything from there.
hope this helps!
Feb 04, 2009 | Microsoft Windows Vista Home Premium with...
Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Jan 09, 2009 | Garmin zumo 550 GPS Receiver
Son-in-law is unable to download a program into PC that we gave
try run windows in sefemode u can log in as administrator there and change under control panel, users the user password
Dec 27, 2008 | Computers & Internet
System software missing
Current version of software is 5.0
Download that as that may be your problem.
You must download the newest version of WebUpdater from Garmin for free to your computer.
Then:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Dec 03, 2008 | Garmin nuvi 260W GPS Receiver
GPS Logo
32 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
