Question about HP Photosmart M425 Digital Camera
LENS ERROR STAYS ON FOR ONE MINUTE AND SHUTS OFF
  • crazydlp9 Feb 19, 2009
    my camera will be perfectly fine and im taking pics and all of a sudden it says battery low and shuts off with the lense staying out
    Sergeant:
    Novelist:
  • 196 Answers
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Posted on Nov 04, 2008
My camera is displaying error 0000018-4489-957-000, what i do ?
The screen would turn red and i would get an error message. I realized the lens lid stayed open even when the camera shut itself off. I hit the corner of the camera a few times (the side with the lens) until the lens lid shut. Then I tried to turn on the camera and it worked!
Mar 14, 2011 | HP Photosmart R727 Digital Camera
Hi, My Kodak EasyShare C613 intermittently starts up ok, but other times the lens extends and the viewfinder stays on the initial screen. (The Kodak EasyShare system 'share') After around 40 seconds...
My camera is stuck on the screen that says "lens error" and then has four different numbers in a row. The camera lens is fully extended and will not shut off...any suggestions of what the problem could be?
Nov 04, 2010 | Kodak EasyShare C613 Digital Camera
I have Sony VPL CS6 projector and the lens cover stays open and wont shut to cover the lens!! The Lens/Cover light on it flashes? It does project for about 15seconds or so but then goes off, this is when...
It is possible that there can be few reasons for the fault siad:
1.the lamp can be faulty
2. the filter can be clogged.
3. the lens cap trigger switch can be faulty and staying on
4.The power supply can be faulty, not delivering the power but shuts off.
5,the main processor board can be faulty witth errors.
It might need board swapping to confirm.
Sep 25, 2010 | Sony VPL CS6 Multimedia Projector
First a black screen, then a lens error
For the lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
WE WENT TO THA BEACH AND TOOK SOME PIC AND LATER THAT DAY WHEN WE WENT TO TAKE MORE PIC IT SAID LENS ERROR RESTART CAMERA BUT WE DON'T KNOW HOW TO RESTART THE CAM
Aug 18, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Lens error
Does it stay when you turn it off and back on again? These cameras have a function that shuts the camera down when there's a mechanical obstruction to the lens extension, It shuts it down to prevent more serious damage to the mechanism. Problem is, sometimes when triggered it doesn't return to normal. Try resetting it, either by the regular procedure, or by taking out the batteries for a few minutes. keep in mind that the lens barrel of this Casio unit is almost all the way to the left edge of the camera. Inevitably, when you hold the camera with two hands, one of the fingers of the left hand will overlap onto the front left edge of the unit, which, in fact, puts a portion of the finger on top of the edge of the extending lens barrel, either slowing its extension outward or aborting the extension process altogether. Even when you instantly jerk your finger away instinctively when the barrel rides the edge of your finger, you still have affected or interrupted the barrel extension process. In my opinion, a design flaw, but who am I to say? Good luck ;]
Jun 02, 2006 | Casio Exilim EX-Z4U Digital Camera
HP Photosmart M425 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
