Question about Apple iPhone Smartphone
I phone I just got an iphone3g--and cannot sync my windows calendar with the iphone--i don't have outlook...am using vista...help!!! please!!!
  • 113 Answers
Hope in iphone u will be able sync all the info using only itunes, try installing and the to sync
Posted on Nov 05, 2008
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
Outlook calendar appointments sync to IPhone but appointments made in Iphone do not sync to Outlook
so what u trying and wanting to do with it here being coneected meens its looking at whatever in i pohone not what u did before cuse if u set it to work online it would edit the date so ya set it offline so it dont think its contecting online program so trricky what and do u have latest firmware in i phone and updates for office outlook ?
Jan 19, 2008 | Apple iPhone Smartphone
I have read all the msg boards and am still not able to sync my iphone 3gs to outlook. does it have anthing to do with running Vista? I used to work then notice that it changed
Vista shouldn't have anything to do with it, unless your using a 3rd party software to connect it.
First thing, Update iphone to latest version.
Update outlook 2007 using windows update.
The resent update to the iphone firmware and itunes fixed the problemof things not moving from iphone back to outlook.
BEFORE the fix for the iphone , to get an event to show up back in outlook , you would need to make it a recurring event on the iphone starting and ending on the one day ...
to test if thts the problem you have , make a new calendar event in your phone and make it recurring, starting and ending on the same day.
sync, then check outlook.
Before this update to get things working I needed to do the following...
1) backup your outlook .PST file. 2) rename and move the existing pst file, and create a new one.. 3)import the contacts 4) import calender events, (not recurring ones) 5)sync.
Taken from: stu @ http://forums.whirlpool.net.au/forum-replies-archive.cfm/1044679.html
Oct 19, 2009 | Apple iPhone Smartphone
Downloading calendar from palm to iphone
In order to get your calendar from Palm to iPhone, you first need to sync your contact from Palm to Windows Outlook and then select the option "sync calendar from Outlook" in iTunes, once selected all your details would be in sync.
Jul 01, 2009 | Apple iPhone Smartphone
How do I sync with Microsoft Outlook calendar and contacts?
Hi, you're right you'll need usb cable however bluetooth can be used as well.The usb cable is supplied with the phone. Vista use the new Windows Contact and Windows Calendar,but you can use MS Outlook if installed and you'll need MS IE v6.
Rate me if helped.Thanks.
Apr 14, 2009 | LG Vu CU920 Cellular Phone
How do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
Apr 03, 2009 | Apple iPhone Smartphone
Sync iphone 3g calendar w/outlook 2007
In itunes go to syncing options and make sure contacts and calender are selected! then resync! hope this helps! Merry christmas!
Oct 03, 2008 | Apple iPhone Smartphone
Syncing outlook 2007 and iphone
BUY A BLACKBERRY. NO PROBLEMS HERE
Jan 03, 2008 | Apple iPhone Smartphone
Sync Outlook 2000
You can transfer your contact list, but not your calender. Here are the steps to take to successfully transfer your contact list from outlook 2000 to the iPhone:
1. In Outlook, export your contact list as a Comma Separated Values (Windows) file
2. In windows accessories, launch Address Book
3. Import into Windows Address Book the file you created in step one
4. Now back in iTunes, sync your iPhone contact list with Windows Address Book
You contacts should come over intact.
Sorry, but there is no solution that I know of to import Calendar events.
JAF
Oct 19, 2007 | Apple iPhone Smartphone
Sync iphone to outlook
Only way i could get any sync was first strangling the cat,wrapping its limp body round my neck,then getting two pieces of celery of equal length.Soaking these overnight in a mixture of lemon juice and urine.Drink the juice at 2 minutes past twelve on a full moon,insert the celery where the sun dont shine and whilst hopping on one footand circling the p.c with the iphone balancing on my forehead.First few times no joy then bingo synched right off.
hope this helps
Jun 30, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
66 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
