Question about Sony Cyber-Shot DSC-P52 Digital Camera
Sticking lens cover on my sony dsc-p52
When i turn on my camera i hear a noise like a motor gear, also the lens cover is stuck in the open position, a message appears saying turn off the power then turn it on again, i have tried this on several occasions with no success The manual states that a lens error causes this problem. Does anybody please have a solution to this problem as the camera is not operational like this.
RegardsTerry.
  • Clydecito Jan 03, 2009
    One of our secretaries bought this camera at the same time my kids gave me one. Both are now useless because the driving gear to open the shutter to the lens won't move. The small drive gear on the electric motor is missing a cog. I tried to simply disengage the motor but it won't allow the camera to turn on. I've got the part number for the drive assembly and found some for $80 or so, just don't know if this camera is worth investing another $80 into, in HOPEs that it works.
techman
  • 3130 Answers
SOURCE: Sony DSC-P100 lens cover won't close
unless you know how to work on camera optics I would leave this one for the pros. Look in your owners manual for a repair depot or call the tech assist # in the book also. Now you may be able to fudge it a bit by when ther cameras off try flicking the side of the lens with your finger a few times if the cover pops out then you know its gummed up and need to be disassembled and cleaned. If it dosent come out after a few perswading flicks then you know that there is some mechanical or electrical problem that needs a service person to check out. Good Luck!
Posted on May 01, 2006
SOURCE: Access Probelm with DSC-W50 camera
I was having the exact same issue with my dsc-w55 and I followed the solution of another post from this site which was: "There is a problem internally with the lens. Likely, the focusing lens is jammed up. The lens will need to be disassembled and fixed, if possible, or replaced. Occasionally, a good "whack" in your hand can fix it. Just don't hit the lens, or lcd; or you can break them. Then there will be more damage." I gave it THREE good "whacks" in the palm of my hand, was careful not to hit the lens or LCD and VOILA! I just shot a few pics with my camera and so far so good. Good luck!
Posted on Sep 06, 2007
avaya pimp
  • 23 Answers
SOURCE: Sony DSC-P52 Lens Cover Problem
check with sony parts and accessories deptment 1800-488-7669
Posted on Jan 31, 2008
  • 3 Answers
SOURCE: Sony Cyber-Shot DSC S90 lens problem - fix or buy new?
I have this camera and it's been broken for a while, I got sand in the mechanism when I was on the beach. (Yes, quite dumb, I know).
I'm a completely a-technical guy, but without anything to lose I opened it up (4 screws, 1 of 'em next to the batteries).
Inside, I lifted the black hatch on the bottom left of the lens. (2 screws). There are 6 (white) cogs of different sizes underneath, which connect to the main (black) cog which extends the lens. Under the white cogs is the motor for the lens, but unless you get absolutely no buzzing or anything when turning the camera on (which would mean your motor is toast) you don't need to go there.
I made a schematic drawing before taking out all the little cogs and sprockets and whatnots. I cleaned them one by one with a needle and put them back using tweezers. I tested it by pushing the main (black) cog with the needle, clockwise, and pulling out the lens manually. It came all the way out, whereas before it didn't, so I closed it back up, and it was fixed!
Good luck.
Posted on May 28, 2008
  • 4 Answers
SOURCE: Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Posted on Aug 27, 2008
Dsc-P52 lens cover sticking
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Feb 24, 2012 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cybershot DSC-P52: Lens Cover Failure
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it's something simple, a power-down reset may help. Turn the camera off, remove the battery, let the camera set for at least 30 minutes, then replace the battery and power up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 18, 2009 | Cameras
When using camera, the lens will not come completely open or clos
You have broken last (black) gear in opening/closing mechanism. Common problem. Need new gear or fix missing "tooth".
Sep 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My camera is showing the error code E:61:00
On Sony equipments this error code seems to be dedicated to focus and lens errors. You may have either some dirt or anything like this inside the lens or focus mechanism, or a broken mechanism (any drop of your camera lastly ?).
If you can open it properly, you should check for "foreign body" inside the mechanism (focus and zoom mechanism, but but code 00 means focus normaly).
Jan 16, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
DSC-P52 Shutter Problem
I have investigated my problem further and basically the teeth on the black cog which opens the lens cover have broken. This a very small component which attaches to the motor, so when you hear the motor, or if you have had grinding noises, it is the mechanism trying to operate the shutter but cannot beacuse the teath won't engage. If you have this probelm all the turning on and off again wont solve the issue. You might be lucky if only one of the teeth have broken but you are only postponing the inevitable which will happen when you least want it to. I have aChristening at the weekend and only hope I can get this sorted by then.
I will need a new shutter mechanism ( don't know the technical terms) but as yet I have to investigate where I can get one. Any suggestions anyone??
Apr legal
Jun 28, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Is there a setting for the lens gear on the DSC-P52?
Jan 31, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony DSC-P100 Lens Will Not Open - Dropped Camera
Motor mechanism is shot Sony customer support for advice My - bet? New Camera And treat this one with some TLC
Aug 21, 2006 | Sony Cyber-Shot DSC-P100 Digital Camera
Turns on but that's all
Oh yes the Sony Click When the camera powers up it must run a duty cycle to check that all circuits and the lenses are functioning properly. What you are hearing is most likely the gear assembly on the lens is out of time. one gear reaches its limit the motor doesn't know because another component is not is the proper orientation and on gear clicks over another. Never reaching the end The software does not get the information that everything is okay and does not allow the camera to function. Suggest professional Repair.
Aug 02, 2006 | Sony Cyber-Shot DSC-P52 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
51 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
