FixYa.com
Tags:
Brother MFC-5440CN All-In-One InkJet Printer
Screen reads "Near empty Cyan" but I just replaced... (by 4 users)
posted by mouth on Oct 05, 2006
I cannot print or receive faxes because the "Near empty Cyan". I just replaced the ink cartridge. It's full.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by wendyroxie, posted on Jul 23, 2008
I have same problem with printer "Brother MFC-440CN". Replaced cyan cartridge and it keeps saying "ink empty"cyan. I unplugged it and started over. I also used air spray in case of dust inside, but that didn't work either. My machine is out of warrantly, but hardly used. Brother won't help me.
Comment by Guest, posted on Dec 22, 2007
change cartridge replace cyan
Comment by Guest, posted on Dec 15, 2007
NEAR EMPTY MAGENTA BUT JUST REPLACED ALL CARTRIDGES
Best Solution
posted on Dec 30, 2007
Helpful (85)
Mergatroid
Rank:Wiz Wiz
Rating: 85%, 103 votes
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 06, 2007
Thanks for Trying (70)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
You should try to update the firmware. That did work just fine for me.
http://solutions.brother.com/Library/sol...
Mike (Mexico, D.F)
Can you Help with these Printers problems?
Memory
My MFC-5440CN will not fax, or... Answer This...
Brother 5440 won't print in...
I use my printer mainly to... Answer This...
Clean ink path to head on cyan...
My printer prints fine except... Answer This...
brother printer
sorry , I didn't see a solution... Answer This...
Wont receive fax
set the fax receive to manual... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
