Question about HP Photosmart C3150 Printer
Printer problem I can scan and print but when I try to print from the computer it says there is a paper jam
  • 41 Answers
Uninstall your current C1350 drivers (you should reboot after the uninstall). Then visit HP and download the latest drivers for your operating system. Try printing.
Posted on Dec 01, 2008
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
After fixing a paper jam, my printer will not print or scan from the computer. Say computer not found. what do i do?
while on jamming the machine the USB cable may have come on plugged check that sure not only to check where it goes into the computer but more importantly where it went into the printer.if that doesn't work try rebooting both devices.
Jul 17, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Not printing after paper jam
Try the HP website. I just downloaded a tool that fixed my problem which was with a 1410 that worked with a Mac and with XP, but not Vista (although it had in the past). Print jobs showed in the queue, there was no error msg, but wouldn't print, either.
Oct 21, 2011 | HP PSC 1410 All-In-One InkJet Printer
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
Cant send nor receive faxes
dear sir,kindly follow the below instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Paper jam
This model has 5 places where you might encounter jammed paper. Since you said you cannot see it, I suspect that it may be one of the following:
1) Inside from the front - (This is a similar to accessing the print cartridges). Raise the scanning unit until it stops (cartridges move to the center). Open the two inner covers. Gently clear the jam. Try not to touch the printer components. Close both inner covers, lower the scanning unit. Press <OK>
2) Inside transport unit - Open the rear cover. Remove the jammed paper or any bits that you may find. Close the rear cover. Press <OK>
Dec 19, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Paper jam
For this and any other print jam problems try this;
Open the scan bed tray and push down the button at the front (scan bed tray open switch)
I found if your print jam occurs and you go through this procedure, the jam clears itself.
With the tray still up and switch held down, try and print something.
See how far the paper goes through the print cycle before jamming. If it jams when it reaches the print head...clean under the print head and try again.
Hope this helps
Mar 17, 2009 | Brother Multi-Function Center MFC-665CW...
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Problems with scanning and printing
You have a very tiny paper jam that you have missed. You need to use a torch and tweezers and get right inside and look thoroughly and down behind in paper feed area. You will find a very small piece of paper somewhere broken off and jammed or a foreign object. Your scanning problem could be corrupted driver. Go to manufacturers site and download updated driver for your model. Uninstall printer completely before reinstalling new driver. Good luck
Aug 25, 2007 | Compaq A3000 All-In-One InkJet Printer
HP Photosmart C3150 Printer Logo
71 people viewed this question
Ben Johnson
