Question about RCA 27F530T 27" TV
Buzzing sound When I plug in my television all it does is make a buzzing sound. I cannot turn the television on. It does nothing but buzz until I unplug it again.
  • valexandrur Jan 18, 2009
    I replaced the output which was shorted.I soldered the driver coil.When i plug the set in with a new driver there is a buzzing sound from the regulator.When i push the power button the set comes on for 3 seconds then it blow the new output.
    Problem Solver:
  • 10 Answers
The horizontal output is shorted ,has to be replaced BUT solder all connections for three inches around the this horizontal and solder them well or the output will blow again,there is especially a small coil in the drive line to the base that causes most of the problem
Posted on Oct 05, 2006
HITACHI MODEL # 53UDX10B has a flashing red light and a buzzing sound
If it was transported likely the set was damaged--one of the three picture tubes used could have been damaged--the flashing light is the set trying to come on and the buzzing is related to whatever is bad.
It needs to be opened and inspected.
May 18, 2012 | Hitachi 53UDX10B 53" Rear Projection...
My TV takes about 15 minutes to start playing.
It sounds like you have a problem with your signal board. The signal board will need to be replaced.
you can get parts for this tv at www.interliquidparts.com
Feb 22, 2012 | Televison & Video
Buzzing TV- Polaroid 37" FLM-3732
i fixed one by put 2 new caps in c112 and c113 1000uf 10v
Jun 13, 2009 | Polaroid FLM-3732 Television
Buzzing
If it is a buzzing noise, it is the Ballast for the lamp.
If it is more of a grinding sound, it is the Color Wheel motor.
Does it go away when you turn off the tv? If so, does it stop abruptly or does the sound tend to get softer (winding down noise)
If the noise stops abruptly it is probably the Ballast.
If the noise takes several seconds and seems to get softer until it stops about 30 sec later then it is the color wheel motor.
Richard Bartlett
Apr 02, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
TOSHIBA 30HF84 DOES NOT COME ON
mine does this same thing and in the manual it says that this is an indication that the bulb is about to need replacement. I did this and still the same issue. The only small solution I have found is to disconnect power and try to turn it on until it finally does. I am searching for a REAL solution though.
Jun 12, 2008 | Toshiba 30HF84 30" TV
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA 27F530T 27" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
