Question about Nintendo The Legend of Zelda: The Twilight Princess for GameCube
I am in the sky city and cannot get to the tower where the boss is .
I got through all the rooms and am ready to face the boss in the sky city but cannot get to the tower where the boss is. I think I need to use the claw shot to pull on the basket thing to get the fan moving but cannot reach it.
You need to claw shot up to the pillar that has vines growing up to where the top is broken off. You can climb up to the top, stand up, and then reach the ball with your claw shot. Use the steel boots to weigh it down and presto!
Posted on Jan 24, 2009
  • 3 Answers
I beat this game along time ago i can help you but i dont no were your at
Posted on Nov 04, 2008
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
Why does mitsubishi split system heats room 5 degrees hotter than setpoint on remote
It could be something as simple as 'solar gain' adding heat through glass facing the afternoon sun....or maybe the remote is not in a location that senses the average temperture within the room. Maybe the remote is located in a slight draft entering the room.
If the remote was kept above a computer tower, the opposite would be the case.... the heat from the tower would keep the control thinking its warmer in the room than it is. The result would be a much colder room.
Mar 10, 2015 | Mitsubishi MUZ-FE09NA-1 MSZ-FE09NA-8 Mr....
What power supply is compatible with a cool master CAC-T05-UW? ATX Mid Tower ATX, Micro ATX compatible form factor 2 External 5.25drive bays 2 External 3.5 drive bay 2 Internal 5.25 drive bays 7...
Hello vonii94,
Welcome, and thank you for using FixYa!
To answer your questions, the sky is the limit! :)
Any modern power supply you would purchase, as long as it is ATX Compatible, will fit this box.
I recommend at least a 750Watt so that you have growing (upgrading) room in the PC. Antec and Cooler Master make some nice ones.
www.newegg.com or www.tigerdirect.com
Have a great day!
Sep 12, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
I'm about to launch into the sky to the City in the Sky, and I need to warp the cannon out to the lake to get it fixed. I saved at this spot, and turned off the game. Today, I started up again, and I...
Yes it is a glitch, and you will have to start over unless you want to try what's on the link below.
http://www.wiichat.com/legend-zelda/15416-cannon-room-glitch-fix-inside-look.html
The thing is with this method, it will not be your original game save file, it will be a new one up to the sky cannon point.
It says: The Save includes-
15 hearts, all bottles, all bomb bags, a lot of items, all bugs, most heart pieces and 45 POES.
So if you want to find all the bugs, poes, etc yourself, you may not want to use this. But if you don't mind having the items already found for you, then you can try this and you won't have to start over from the beginning. Hope this helps you :)
Jan 25, 2011 | Nintendo WII The Legend of Zelda Twilight...
I am on forest temple level andhave to get that gale boomerang and i know you have to defeat an boss to get it, but which room is the boss in?
You don't have to defeat the boss to get it, you need to defeat the baboon monkey creature. You'll need to save some monkeys from their cages and head to the biggest room with all the doors and go to where the baboon took down the bridge. Now you can cross the gap using the monkeys and get to the room where you can fight him for the Gale Boomerang. He's in the room labeled #10 on the map.
Oct 28, 2010 | Nintendo WII The Legend of Zelda Twilight...
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Re Garmin Streetpilot i3 Satellite Problem
you should be able to use ur garmin I3 with the top facing the sky thru ur windshield just fine. Just like the one in this video http://www.youtube.com/watch?v=qCLiEOinqAU
If the problem still exists then try reinstalling the maps again. Make sure you have the Map Source and City navigator installed from the Cd provided. And install the maps once again like u did at first. It should fix the problem.
Sep 19, 2008 | Garmin StreetPilot i3 GPS Receiver
Hi there, I live in a apartment on the side of my bosses house & he has 2 sky boxes, his is sky plus & mine is a normal box. Their both run off the same contract not separate. But when my boss...
if it is the same as directv - you used a splitter on the cable between the 2 boxes - you need to us a multi switch - or dual lnb
fyi - the boxes change channels by varying the voltage to the dish - if 2 boxes are giving different voltages it does not work
thanks
scott
Jul 31, 2008 | Televison & Video
Garmin 250
It needs time to find out where it is...just leave it with flipped open aereal facing open sky for several minutes and see if it knows where it is after that....
Mar 10, 2008 | Garmin nuvi 350 GPS Receiver
Nintendo The Legend of Zelda: The Twilight Princess for GameCube Logo
415 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
