Question about Panasonic PT-60LCX64 Television
Panasonic PT-60LCX64 Air Filter Cleaning
Dear FixYa Guru,
My 60inch Panasonic just prompted me the "Air Filter needs cleaning" message. Not in that exact context but it is due for one after being owned for nearly 3 years. My request is for directions to manually access and clean this air filter without hiring the professionals. To be more specific, where are the spots to clean inside and around the television. I've heard that it is a pretty nickel to have it done by the pros.
Many thanks in advance,
Hai Nguyen
  • gtcnch7 Jan 07, 2009
    I have a panasonic pt50lcx64 and have the same problem. Have you found a solution
Cleaning filter for the Panansonic PT-501LCX64.
I just had a T.V. tech do this. The filters are located on the two removable filters on the back side of the T.V. They look like the speaker units. He removed those two units, unplugged them & set them on the floor. He took some type of electronic cleaner with a cloth & wiped them down. The filters themselves are plastic. He explained that air flows through some tube connected to these plastic filters for cooling down below. He admitted they didn't look dirty--put everything back together & it is working fine now.
I imagine that dirty or not the timer is automatically set for every 400 hrs. of use to give you the prompt that the filter needs cleaning & will shut off in one minute so you can call a T.V. tech?
So to reset the timer--follow the other detailed prompts listed on this board & or use your owners manual & follow the prompts for replacing the bulb. That should take you somewhere to reset the timer--so you have another 400 hours of operation.
I believe it's with the T.V. turned off--hold down the down volume on your tv itself while holding the swap button on the remote control for 5-7 seconds---then follow the prompts. You should see a prompt for replacing a bulb & then one for filter cleaning. Then just reset the timer.
Hopefully this will help?
Posted on Feb 19, 2009
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Jan 06, 2014 | Panasonic PT-40LC12 40" Rear Projection...
My PT-60LCX64 says i need to clean my air filter i took off the back panel and cleaned all the dust out of it but did not find the air filter i took off the speakers thinking they were the air filters and...
The air filter is deep inside the set. You need to dismantle the unit and get the light engine out. I would highly recommend calling an authorized service center to do this for you.
But if you insist, email me at XPxAxBxLxOX@comcast.net and I will bounce back the service manual for you.
Jan 07, 2010 | Panasonic PT-60LCX64 Television
A message keeps popping up saying I need to clean the air filter then the tv shuts off on it's own. It's a panasonic 60 inch projection
there is a louvered air intake panel on either lower side of tv. there is 1 or 2 screws the filter is right behind that panel.. take it out and clean it with warm dishsoapy water and pat dry on a flat surface with paper towels then reinstall. your th will not come on till the panel is screwed back into place. there is a microswitch type sensor that makes sure that the screws are in place...goodday
Nov 13, 2009 | Panasonic PT-60LCX64 Television
Air filter cleaning panasonic pt-60lcx64
Good idea.....do you have a problem with it??????????????
Jul 15, 2009 | Panasonic PT-60LCX64 Television
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Air filter keep popping on screen and shut off after 1 minute.
I had the same problem with my Panasonic tv, just 3 days after a technician came out to fix "fuzzy spots" which were multi colored, but mostly green spots. I really thought that the technician was in some way responsible, but Panasonic insisted that there was no possible way he was. It was going to cost $240.00 for him to come out to clean the air filter, and both the technician and Panasonic insisted that I couldn't do it myself. I had decided to buy a new tv to cut my losses. My boyfriend talked me into trying to fix it, we are both sort of mechanically inclined, and it was going in the trash anyway.
We took the back and top off the tv. It took some looking, but we finally found the filter, just over the projector. We removed the cover, it has to be done from the back of the tv, it is black and held on by 4 small screws, be careful not to drop them into the tv, we dropped one, but it shook out. We vacuumed the filter really well, and vacuumed around everywhere. We put the tv back together, not expecting it to work, but thinking at least we tried. It works great. It has only been a few days, but it seems like the problem has been solved.
Good luck if you decide to try. I have decided not to put another penny into the tv.
Jan 07, 2009 | Panasonic PT-60LCX64 Television
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Jun 11, 2008 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-60LCX64 Television Logo
3,227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
