Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Zenith D52WLCD Rear Projection HDTV Ready
When hooking up a HD cable box or a DVD player to my component inputs, all I get is "no signal" message. What is the cure?
  • 5138 Answers
SOURCE: Reset Lamp
Look in your owners mannel if you still have it,it should tell you lamp reset code.
Posted on Sep 04, 2008
  • 203 Answers
SOURCE: Zenith d52wlcd 52in rear projection
How this is it? Is it perfect or is it like a blob of blue going down the screen? can you see the picture behind it or is there no picture in that area?
Posted on Sep 15, 2008
SOURCE: d52wlcd
I was watching a movie and the screen went black i do have sound. what it can be?
Posted on Nov 25, 2008
  • 12 Answers
SOURCE: My Zenith Projection HD TV is displaying a series red lines
It probably needs the convergence circuit repaired by a qualified technician.
Posted on Sep 09, 2009
  • 157 Answers
SOURCE: zenith model D52wlcd projection TV
The Lamp will no cause any color distortion. The "Replace Lamp" message comes up after a certain amount of hours after watching the TV because the lamp only last a certain number of hours before needing a replacement one.
It sounds like a light engine problem. There is no quick fix, you need to replace the whole light engine which is very costly (light engines usually run at least $500) and time consuming (need to take whole TV apart to replace part).
Posted on Oct 07, 2009
Testimonial: "Thanks. My son also thought it was a light engine. You advise is very helpful!"
  • 1121 Answers
SOURCE: My zenith D52WLCD has a blue haze going diagonally
This a Normal Intensive Use Defects, this a Screen Burnout. Sorry
Posted on Oct 31, 2009
0 characters
1 Points
I have a D52W20. I bought a HDMI cord thinking it was what I need, what is it that I DO need for HD?
To correctly get HD, you need to satisfy three things.
First you need an HD tv.
Second you need an HD signal. IE.. HD cable box, Blu Ray etc..
Last, you need either HDMI wires or Components wires.
Hook the HD box up to the TV with component wires(I believe you tv doesn't have hdmi connections), go to the correct input and enjoy.
Feb 20, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
If these tv is digital why I need to use a converter box to see the channels
Because it does not have a ATSC nor a Quam tuner in it. Just a regular tuner. As it says HDTV ready. This meant back when you bought it that it will receive HD when a hd cable box is used and connected to the DVI or the Component input in the back. This was a low end set at the time. It will still receive regular cable without a box.
Nov 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
How do I get the HD on this model? Which cables/hook up should I use? I do not have a cable box or set top box but if these are required, please let me know. Thanks!
Your unit is HDTV ready but is not an HDTV. It is capable of displaying HDTV only through the component inputs. Your tuner is analog NTSC and will not receive HDTV or digital.
You could get an HDTV picture using a Blue Ray DVD and hooking up the component connectors from the DVD to the TV.
The only other way would be to get an HDTV tuner with a component output and hook it up the same way, component out to component in, and hook the tuner input to an off air antenna (receiving HDTV) or cable or satellite with HD signals.
Thanks for using FixYa and for the great rating.
Sep 21, 2010 | Sony KP-51WS510 51" Rear Projection...
My 53UDX10BA is HDTV-ready. Where can I get the
Your TV accepts HD inputs from HD cable boxes, video game systems, Bluray players etc. There is no adaptor needed just connect the HD device to the component inputs on the back of the TV which are GREEN/BLUE/RED in color. Please take a moment to rate my answer. Thanks..
Nov 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
AT&T Uverse HDTV
on some of the HD ready projection TVs they have a separate input for component HD, also some have a separate component input for HD
Mar 28, 2008 | Samsung HLN5065W 50" Rear Projection...
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Jan 29, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
15 people viewed this question
Top Zenith Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Zenith Projection Television Expert? Answer questions, earn points and help others
