Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
I purchased a Kenmore 80 Series in December 2005.  Six months later while we were away for 48 hours, the washer started filling itself, overflowed the tub and flooded the entire house.  I 'chalked' it up to a freak accident.  Recently, the same thing happened again flooding the house again.
Are there any known problems with this series of Kenmore washers?
model # 110.26852502 serial # cs3306909
The unit still works properly, and runs through its cycle with out any problems. What could possibly be the problem (electronics, valves, regulators, pressure surges, power surges, paranormal activity, etc.).
Please Help!  Thanks.
  • levhouse Nov 07, 2008
    I am having the same type of problem...my kenmore washer overflowed in 2006 and the Sears repairman came and couldn't find a problem and told me the machine was safe to use. Then in October 2008 the machine overflowed again, causing substantial damage to my home. Now the Sears repairman say they can't locate the problem...they can't find anything wrong with the machine, and it isn't overflowing. HELP! I can't afford another $5000 worth of damage!
  • mattkennett Nov 26, 2008
    My machine kenmore 80 sreies washer overflowed and would not drain. I have the machine apart. Pump was not clogged. Motor turns by hand. Is there a piece missing between pump and motor? Please help before wife comes home!
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Posted on Jan 10, 2009
    President:
  • Kenmore Master
  • 2,651 Answers
Faulty valve would let water in.(never shut completly), and trickle in water very slowly.best way to avoid flood until problem is found is to shut water suppply between uses( not a bad habit to get into)
Posted on Nov 05, 2008
Hey thank you so much aborcass your solution worked perfectly. Now my washer is washing with ease.
Posted on Dec 02, 2009
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
How do you remove the top off the washing machine to replace the lid switch in a kenmore super capacity 80 series?
The following link explains step-by-step how to replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Oct 26, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series top loader washer overflows
It will not be a sensor,,,it will be what is called a "Ball **** valve" and they are pretty cheap to replace.
This same valve is in your toilet tank.
Jan 19, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series overflowed!!!
The most common cause for this is the water mixing valve plunger sticking. the fix is to replace the mixing valve. Not so common is a defective water level pressure switch. Same fix, replace the switch. Really rare is a small leak in the tube from the tub to the pressure switch.
Feb 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
3,450 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
