Sony TA-S7AV Amplifier, part of a stack
I get an error when i turn on the system saying push power, protect. we have taken the unit apart to see if there is anything obvious but all we found was that it was covered in dust. can you help?
    Novelist:
  • 189 Answers
The 'protect' message indicates that the units thermal protection mechanism was activated and has cut output to the speakers. Causes vary, but the idea is that there is some problem with the impedence from the speakers to the power amplifier part of the receiver. Could be that the speakers are wired incorrectly or that they are just actually too powerful for the receiver to properly supply.
So check the speaker wiring for positive/negative polarity, frayed wires, disconnected wires, etc., or try to disconnect them all together and see if the receiver starts.
If not, other causes could be blown fuse (cranking the volume too load could blow a fuse). So you might want to check for any servicable fuses in the unit and replace any that are blown.
The thermal protect circut can just activate on its own and reset on its own. This might indicate that the unit is faulty or just got over heated (try moving the unit away from a heat source - or allowing proper airflow around it). If this circuit is faulty the unit could need repair.
Hope this helps.
bd.
Posted on Nov 20, 2008
    Problem Solver:
  • 17 Answers
The first thing I would do is take the cover off and blow it out with compressed air. Sometimes that's all it takes. If not, look for corrosion everywhere you can. If there is corrosion it will have to be removed. If it's on any legs of capacitor, all those capacitors need to be replaced. Other than that, I'm not familiar with it enough to pinpoint a particular failure from your description.
Posted on Nov 07, 2008
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
Sony TA-N9000ES Power Amplifier Problem: I have a
I have just purchased a Audiosonic Soundbar KW-3508 and connected it up to an existing cetre speaker connection but could get no sound.Any suggestions?
Aug 04, 2013 | Sony Audio Players & Recorders
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
Dec 20, 2012 | Sony DAV-HDX500 System
My home theater system is showing push power protector on the read out and nothing is happening.
Push power protect is an error message that shows unit got some problem in output amplifier section and protection circuit is activated to avoid further damage.
Local tv repair shop will help you to fix it as unit will take apart and soldering work is also involved to replace bad amplifier output chips.
Aug 25, 2010 | Sony DAVHDX265 System
It comes on and goes back off, and is asking me to push power pro
HiFi system goes to standby because protection circuit detects error in amplifier section, you need to take unit to qualified tech for fix.
Jul 24, 2009 | Sony LBT-W300 Shelf System
It says push power protector on my new sony surround system i cant do anything with it
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Apr 17, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Power Protect still comes on now and again
Amplifier output chip in stereo is defective and unit gives error message of push power protect.
You need to replace output amplifier IC and check supplied voltages.
Feb 28, 2009 | Sony MHC-RXD5 Shelf System
Protector push power - dvd home theater system
Bad speaker wiring.
Internal fault.
Regards.
Jan 20, 2009 | Sony STR-DE875 Receiver
Protect light
Protect means that an internal error, as a blown component, a short , or a wrong voltage had been detected.
Try unplugging the unot from all cables, including power cord, for ten minutes. If the unit is still on protection after restart, then you need to have the receiver taken apart and inspected by a technician.
Jan 05, 2009 | Sony STR-DE875 Receiver
PROTECT PUSH POWER IT KEEP SAYING WHAT TO DO
My Sony audio set keeps saying push power protect and the set freezes what should i do? Please help me solve this problem.
Apr 20, 2008 | Sony LBT-XGR6 CD Shelf System
Open Questions:
509 people viewed this question
 Grubhead
Grubhead
