Question about Roper RAS8244KQ Top Load Washer
My washer will not fill, it just drains stright out so the watter will ran for three hours. I just did a load the night befor and everything was fine. I did not move or disturb the washer in any way between the last load and now. What is wrong?!
  • 1 more comment
  • dbdreaux Jun 01, 2008
    My washer starts filling...and before it finishes filling the water appears to be draining out and the water just continues to run...sometimes, it doesn't hold water at all and just drains out as it is filling!!!! Sometimes the water will run for hours ... then I will spin it out and it may run fine the next load.
  • slappytg Aug 28, 2008
    i had the same problem , but by spinning it for about 1 min it works great m ight sounds strange but it works, i had mine running all night thought i put in a new load had to think for awhile thought i was nuts and saw it was the same cloths ... oh my water bill. working now , just watch it , it will do it again .
  • Anonymous Oct 28, 2008
    The Syphon diagnosis sounds right. Did it fix the problem? I have the same problem.
    President:
  • 878 Answers
Candy, check the drain hose, make sure it has a air gap and that it is not down too far in the drain. Sounds like a siphoning problem....Catriver post back.
Posted on Oct 06, 2006
I have an Amana front load washer, it will run through a complete cycle when empty but will not run with a load in it.
Hi Ben
I see you have posted on this before , I think you may have done this already judging from your post , but have you checked the filter on the drain pump? also when you run a cycle empty, is it filling and draining the water correctly , or is there water left in the machine , and last is the drain hose high enough to make sure that there is not a "syphoning" effect taking place as in when it fills with water it drains at the same time , just a thought let me know.
Oct 13, 2017 | Amana Front Load Washing Machine Washer...
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
We have a ge front end washer.it will fill up anddrain but will not spin or agitate.it made a grinding noise the other night before it quit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2010 | Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Won't stop filling basin and doesn't agitate.
check your pressure level hose. it probably pulled off at the tub or the pressure switch
May 18, 2009 | Hotpoint VBXR1090D Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Roper RAS8244KQ Top Load Washer Logo
87 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
