Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error Msg F02
Kenmore Elite HE3T. Getting error code F02. Can you let me know what this means. Thank you
  • 4 more comments
  • Simon Finlayson Oct 10, 2006
    I went ahead and did everhting you said. It ran fine for the next run or two but now the F)2 error is startting again. Any advice.
  • dianal388 Jan 25, 2008
    Hi
    Please help me too, I have same problem, that error F02 msg. I have to hit pause to cancel the beat and the start again, but every time when it done one of cycle it will beat again error F02........
  • ladyangel Feb 03, 2008
    me too and i cant find my manual, its driving me crazy
  • Anonymous Mar 07, 2008
    We had the same problem and cleaned out the filter, checked everything you said to check, nothing is in the hose or filter, We still have the same problem and the tub stinks like spoiled eggs. What should we do next?
  • colonel rick Apr 17, 2008
    f02 alternating with SUD.
    remove front bottom panel, three TORK screws on bottom (I used a small allen wrench) unscrew filter cover and clean out all the ****!
    You will get a lot of water pouring out, so be ready with many towels.
  • Anonymous Mar 14, 2014
    Getting the F35 error on the HE3t... I replaced the pressure sensor about 6 months ago and it has worked fine... but now have the error again ?
Had the F02 error as well. Thanks to all great posts here, esp. colonel rick, catriver and bullfrog7. Use a Torx (star) screwdriver to get the three screws off the bottom of the front plate (I dropped a screw, so was glad I had a magnetic reach tool). I saw the trap, and began to unscrew, and water started pouring, so I immediately re-closed. THE WATER IS AN ISSUE, SO BE PREPARED. Big problem for me was I had the drawer unit beneath (water leaking through ... messy). Grabbed a few towels, but then took bullfrog7's idea of the shop vac. Sucked what I could out of the drum (had a load going before the error), Then I unscrewed the front screw from the trap, and slid the trap unit forward (be careful of the wiring harness unit). This enabled me to pour water from the trap into a mop bucket. I then used the vac to **** what I could from the drain pipe. Our trap had 3 baby socks and untold lint. Washed the trap, put it back together, and voila! No issues. If I can do this, you can too!
Posted on Aug 19, 2008
    President:
  • 878 Answers
Hamish, that is the code for long drain. Make sure the drain hose is not kinked. Remove the bottom panel and and check the drain filter. It is right in front and just unscrews. Get a bucket handy to catch the excess water. After cleaning out the filter strainer check the impeller (hole to the right) to make sure nothing is jammed in there. Catriver...post back.
Posted on Oct 06, 2006
    Problem Solver:
  • 3 Answers
BIG THANK YOU to Colonel Rick, the solution worked perfectly... I did find one improvement... before you pull the filter out... if you have a vacuum which works as a wet vac (I have a Rainbo knock-off called a Hyla) pull all the water out of the tub (you may have to empty your vac one or more times) and then have it ready (basin empty, machine running, hose in one hand) when you pull the filter... minimum muss and fuss, and a very happy crew when the machine is "up and running" in no time, sans ridiculous service call charge and multi-day wait!!!
Posted on Aug 11, 2008
I have same error but when i open the filter at bottom no water drains out! there is no water in the drum but clothes are very wet still. pump is only 8months old. any thoughts?
Posted on Oct 19, 2011
Thanks for the help, in our case it was a nylon on the right side of the filter drain.
Posted on May 18, 2008
Drain hose plugged the hose that is on the outside of the washer
Posted on Mar 09, 2008
    Problem Solver:
  • 16 Answers
I followed the advice given here for my exact same problem today....and it worked beautifully, just like everyone said it would! TONS of water to drain, so have a HUGE bucket available and towels to keep the water from getting out of hand. To prevent it from re-occurring, look into buying a "sock bag" that is basically a mesh net bag that you put your socks/panties into so that they can't get stuck in the drainage system in the future.
Oh, and you may need a "Torx" screwdriver head.....I did.
Posted on Feb 28, 2008
After wasting about an hour pulling off the back cover and starring at lots of things I have no business touching. I pulled off the lower front cover by removing 3 screws. Inside there is a turn style white plug. I guess that is the filter, inside was was verious things that do not belong likes little socks and beer caps and things like that. washed out the filter screwed it back in and works perfect.
Posted on Feb 02, 2008
Take the front panel off (it's simply three hex screws along the bottom and a nudge upwards that do the trick), unscrew the cap to the pump filter, have a bucket handy for the torrent of water behind it.
Most likely that's the problem. In our case it was a hairball the size of my fist. Yay for dogs.
Posted on Dec 22, 2007
I took the lower front panel of my wifes front load Kenmore Elite HE3t which exposed a filter trap. I unsrewed the filter and there was a pair of underwear that had gotten past the filter and clogged the pump/drain. It was wedged in pretty tight.
Posted on Jun 22, 2007
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 06, 2010 | Kenmore HE3T Washer
Kenmore elite washer he3t- beeping F02
"F/02"
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 13, 2010 | Kenmore Washing Machines
After f02 code came up ran a test and get c00 andhttp://www.fixya
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 27, 2009 | Kenmore Washing Machines
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Keep getting f2 signal on kenmore elite quiet pak he3t
F2 and F02 error are one and the same. My daughter was doing a load of towels in my Kenmore Elite HE3t front loading machine, when I went back to put them in the dryer the washer had a load of water in it and an error reading of F02. Checked the manual Could not find anything wrong with the Drain Hose?
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display.* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
May 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite F02 code even after changing to a new pump.
remove compartment cover under the front load door. There is a drain there that will catch large items left in your clothes, ie pens paper etc
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
783 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
