Question about Panasonic KX-TG1100 Cordless Phone
Kx-tg1100 I register my kx-tg1100 to work like handset with another base. Now I cant preregister to his own base. I try to reset base but when a pres "SETTING BS" noting happend (?INPUT CODE? doesnt show) so I cant do anything. Now I can use my kx-tg1100 only like handset with my base. There no problem to cancel that option, but I cant make it to work like before (to have it own signal)
    Problem Solver:
  • 15 Answers
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Posted on Nov 23, 2008
I register my kx-tg1100 to work like handset with another base. Now I cant preregister to his own base. I try to reset base but when a pres "SETTING BS" noting happend (“INPUT CODE” doesnt show) so I cant do anything. Now I can use my kx-tg1100 only like handset with my base. There no problem to cancel that option, but I cant make it to work like before (to have it own signal)
Posted on Jan 10, 2010
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
I have two pairs of panasonice codless phones and a couple of them no longer seem to be paired with the base. How to do I solve this?
Deregister your handset by dialing *331734# then selecting the Menu/Select button. Phone should ask you to place in base to register. Wait a few moments and you should be able to user your handset.
Apr 07, 2011 | Panasonic KX-TG1100 Cordless Phone
I have a uniden TRU9488 preregistered handset from factory, which for years no problem, but stupid me thought "what is this register" and hid register, and now my handset won't work. followed...
What happened is you have deregistered your handset from the tru9488 base. To correct this, you must register that handset with the base. See https://www.manualslib.com/manual/185023/Uniden-Tru9488.html?page=24 for short and sweet instructions for doing this, reproduced below:.
Registering.TCX905.Accessory.Handsets,.or.Other.Compatible.Handsets If.you.purchase.an.accessory.handset,.you.need.to.register.the.handset.before.use..Only.one.handset.can.be.reg-
istered.at.a.time..Handsets.supplied.with.the.phone.are.registered.to.the.base.by.the.factory..When.charged,.pre-
registered.handsets.display.a.handset.ID.number..Handsets.that.have.not.been.registered.display.MODELS.VARY!.
PLACE.HANDSET.ON.THE.BASE.FOR.REGISTRATION.OR.REFER.TO.OWNER'S.MANUAL..(If.an.accessory.
handset.has.ever.been.registered.to.a.base,.you.must.reset.the.handset.before.you.can.register.it.to.a.new.base..
See.Resetting.the.Handsets.on.page.24.)
When.you.register.an.extra.handset.to.the.base,.the.handset.ID.will.be.assigned.
M o d e l s v a r y !
P l a c e H a n d s e t
o n t h e b a s e f o r
1)
Before.registering.the.TCX905.or.other.extra.handset,.the.battery.pack.MUST.be.charged.for.5-20.hours.
2)
With.the.base.in.standby,.press.the.MENU.soft.key.
3)
Move.the.cursor.to.select.REGISTER.HANDSET..Press.the.OK.soft.key.
4)
On.the.handset,.press.and.hold.[#].until.you.hear.a.beep.
5)
While.the.handset.is.registering,.HANDSET.REGISTERING.will.appear.in.the.dis-
play...
When.REGISTRATION.COMPLETE..is.displayed;.the.handset.has.been.registered.to.the.base...
If.REGISTRATION.FAILED..appears,.please.try.these.steps.again.
Aug 10, 2017 | Uniden TRU9488 Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Kx-tg1100 registration to anoter base
sorry, it seems that they have to come from the same model base. however, the procedure to reset handset numbers for the 1100 may work for you. there is a 15 digit number on the base unit. try to type that into the 1100 and see if that will register the 1100 to your old base.
Dec 12, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic KX-TG1100
yes!
sorry, it seems that they have no manual for this model base online yet. however, the procedure to reset handset numbers for the 1000N may work for you. there is a 15 digit number on the base unit. type that into the handset using the book (was on page 54 for the 1000n) for your 1100 and see if that will register the other 1100 to your base.
Nov 26, 2008 | Panasonic KX-TG1100 Cordless Phone
KX-TG1100 base charger
unable to locate the part on the website, but can call 1-800-405-0652 to try to order it from panasonic.
BTW, is it the ac charger # PQLV19CE ( item # (1) ) or the base # PQLV30018
(item #(9) ) from the book?
Nov 23, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic KX TG1100 base unit does not ring
I do not think there is any chance to make the base ring for this particular phone. Anyhow, if you discover how to do it throw me a note.
Nov 20, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic KX-TG1100 Cordless Phone Logo
980 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
