Question about JVC HD-61Z575 61" Rear Projection HDTV-Ready Television
Picture has no Blue (sometimes)
Two possible states after power on (remains in this state until powered off and back on) State 1: Working fine. State 2: No Blue (Reds and Greens OK)
    Sergeant:
  • 337 Answers
Try taping on the top and sides to see if the set reacts and the color blue returns,if it does it is likely a loose conection and the repair should not be expensive and you already know whats wrong,if you are familiar with tv service this information will give a place to start but if you are not too familiar be safe and call fos assistance from a servicer.
Posted on Oct 05, 2006
How do you replace the ignition switch on a 2002 buick century?
What do you mean no sound when turning key ? Does the car start an run ? Or the car doesn't crank ? Ignition switch's do not work the same way they did in the old days , especially on GM vehicles . The ignition switch is an input to the BCM - body control module , the BCM processes these inputs an then energizes relays to turn things on . Also sends messages to other modules for them to turn on or energize relays .
The power mode signal may be as simple as a B+ input wired to a particular ignition switch contact. If this is also the B+ supply to the module/device, the module/device will only operate with the ignition contact closed to B+. An example of this is the starter relay when it is wired directly to the CRANK/START contact of the ignition switch. When the CRANK/START contacts are closed, the starter relay is energized and provides a current source to the starter and starter solenoid. When the ignition switch leaves the CRANK/START position, the switch contacts open and the starter relay is de-energized. This removes the current source from the starter and solenoid and the starter operation stops.
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 4 signals/circuits from the ignition switch. These are the Ignition 0, Ignition 1, Crank and Accessory 1 ignition switch signals/circuits.
To determine the correct power mode the BCM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (open = 0)
The sequence of switch closures received by the BCM
The status of the engine run flag.
Important: Any ignition switch states not covered in this table indicates a DTC setting situation.
The chart indicates the modes detected and transmitted by the BCM:
Power Mode Selected/Expected
Engine Run Flag Serial Data
Sampled Ignition Signal State
Power Mode State
Accessory
Ignition 0
Ignition 1
Crank
OFF-LOCK
0
0
0
0
0
OFF
Accessory
0
0
0
ACCESSORY
RAP
0
1 to 0
0
0
0
RAP
OFF-UNLOCK
0
0
0
UNLOCK
RAP
0
1 to 0
0
RAP-UNLOCK
Run
0
RUN
Crank
0
0
CRANK
Crank
CRANK
Run
RUN
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the BCM fail to send a power mode message. The fail-safe plan covers modules with discrete ignition signal inputs as well as those modules using exclusively serial data control of power mode.
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid BCM message until they can check for the engine run flag status on the serial data circuits. If the BCM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to "RUN". In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You probably won't understand any of this info. your best but would be to take it to a qualified repair shop that has proper diagnostic test equipment !
Sep 29, 2016 | Buick Cars & Trucks
Ignition switch for 2003 malibu ls
Ignition switch ? Key an lock cylinder or the electrical part ? The vehicle keeps running or you can't turn key to off ! Different thing's come into play depending on which is your problem ! If vehicle doesn't shut off (keeps running ) You need to know how it works !
An ignition switch isn't the same as back in the old days , it's a low voltage input to the BCM .
On vehicles that have several control modules connected by serial data circuits, one module is the Power Mode Master, PMM. On this vehicle the PMM is the BCM. The PMM receives 3 discreet ignition switch signals to differentiate which power mode will be sent over the Class 2 Serial Data circuit.
To determine the correct power mode the PMM uses the following circuits:
Ignition 0
Ignition 1 voltage
Ignition 3 voltage
An you need a professional scan tool to deal with these problems !
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid PMM message until they can check for the engine run flag status on the serial data circuits. If the PMM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to RUN. In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Aug 31, 2016 | 2003 Chevrolet Malibu
I have a 2009 g envoy and when I turn my key it wont do anything.replaced the ignition switch and it has worked fine for about 5 months and now it is doing the same thing sometimes it will start right
On GM vehicles starting back in mid 2000's , maybe even before that. They started using inputs to the body control module from the ignition switch, from there the BCM controls all vehicle systems .
Power Mode Description and Operation
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the body control module (BCM). The BCM uses 3 signals from the ignition switch. These are the Ignition 0, Ignition 1, and Accessory.
The chart indicates the power modes detected and transmitted by the BCM:
Correct Ignition Switch Inputs
Ignition Key Position
Power Mode Parameter
Engine Running
Accessory
Ignition 1
Ignition 0
OFF
Off-Awake or RAP
No
Inactive
Off
Off
UNLOCK
Unlock or RAP Unlock
No
Inactive
Off
On
ACC
Accessory
No
Active
Off
On
ON
Run
No
Active
On
On
START
Crank
No
Inactive
On
On
ON
Run
Yes
Active
On
On
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the body control module (BCM) fail to send a power mode message. The fail-safe plan covers modules with discrete ignition signal inputs as well as those modules using exclusively serial data control of power mode.
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid BCM message until they receive the engine status from the powertrain control module (PCM). If the BCM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is true, indicating that the engine is running, the modules fail-safe to Run. In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is false, indicating that the engine is not running, the modules fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You would need a scan tool that can read data from the BCM . What may be the problem is a lose connector , these pin's at connectors are tiny and doesn't take much for one to become lose.
Jan 16, 2015 | 2009 GMC Envoy
Sometimes my 2001 Chevy Tahoe has no power at all nothing, then everything goes back on then it will start
How are battery an connections ? Do the headlamps work when this happens ? How familiar are you with the electronic on your vehicle ?
This could be an ignition switch problem , a BCM - body control module , The ignition switch is a Discrete Ignition Signal to the vehicle BCM body control module . The Body Control Module (BCM) performs multiple body control functions. The BCM can control devices directly connected to its outputs based on input information. The BCM evaluates this information and controls certain body control systems by commanding outputs on or off. The BCM control inputs can be:
GM has had a problem with ignition switches , but the thing to do is hook up a scan tool an check for the correct power mode .
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 2 signals/circuits from the ignition switch. These are the Ignition 1 and Ignition 3 signals/circuits.
You may want to take this to the repair shop an that doesn't necessarily mean the dealer !
Jun 29, 2014 | 2001 Chevrolet Tahoe
I bought a Bamboo Splash a while back, and it had been working fine up until today. I sometimes unplug my tablet and use the cord to charge my phone. Today when i disconnected my phone and put the cord...
Unplugging the tablet would not hurt it in anyway. A power surge can cause such a problem though. Typically the problem you are describing is caused by bad flash memory which is what all tablets use and run on Like a....Example: A Solid State Drive "SSD"
Nov 09, 2013 | Wacom Bamboo Splash Pen Tablet
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
Mar 15, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
The tv picture goes out
Sounds like the ballast has gone out. Samsung recommends replacing the smps board(power supply board) when you replace the ballast because it is the smps that takes out the ballast. replacing just the ballast ,machine may work ok for a short time but will destroy the new ballast fairly quickly.
Dec 30, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Blue band about 6
CONVERGENCE CIRCUIT FAILURE
Dec 26, 2009 | Televison & Video
Garmin Nuvi --Can't put state in for address
Turn on the unit and go to Settings
Then select Map
Then select Map Info
Verify that there is a check mark next to City Navigator North America NT
May 17, 2008 | Garmin nuvi 350 GPS Receiver
Screen whites out on boot up
try this test: put your PC into hibernate mode after the event of ..."After about an hour in this state, the screen will, after a further power on and off, resume normal operation. Functions perfectly...". Then force a hibernate state (START-SHUT DOWN-hold shift while hover STANDBY). Now, while in hibernate state, force a "resume Windows" state (space-bar on my PC). Any change on display to note? Hoping you answer yes, it is better now. If so, then continue with hibernate mode.
Jun 14, 2007 | Xerox XA7-192i 19" LCD Monitor
JVC HD-61Z575 61" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
