Home Logo
Al Scott Posted on Mar 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Resetting toilet wax seal
Floor flange not level
Arthur
Level 3:
  • Master 458 Answers
  • Posted on Mar 18, 2012
Arthur
Master
Level 3:
Answers
458
Questions
Helped
181368
Points
1325
A friend of mine had this problem in his "house"(it used to be the garage for the other house on the lot,definite signs of ******* construction).After trying a new wax seal 3 times,he just put 2 on at the same time(this required him AND his girlfriend to put their weight down to seat it)and I'm sure it will be a mess for the next renovation,but it didn't leak anymore!
5 Related Answers
mindreader
Jim DuBreck
  • 578 Answers
  • Posted on Dec 31, 2009
SOURCE: Toilet on uneven floor
I believe that I qualify... over 300 toilets installed in the past 15 months!!
I would go with the wax rings... but I would press the ring into the base of the toilet before installing the toilet....that way you are sure to have a good seal to the toilet....
If you actually read the directions, the manufacturer will tell you to press the wax ring onto the toilet....then install it onto the floor drain.
I guess that a PLAIN wax ring placed on the floor drain (since it is recessed) before placing the rubber-sleeve equipped ringed toiled is a good safety measure... I have done that an it work about 37 times out of 40.
Good question - BTW.. and well worded. THANKS for being specific and precise!!
Testimonial: "Sounds like a good idea. Not sure about the plain wax ring on the floor however. Doesn't this wax ring need a rubber sleave going into the drain?"
Anonymous
  • 8197 Answers
  • Posted on Oct 18, 2009
SOURCE: Toilet - replacing a wax seal
No when you put the toilet on a new wax ring you need to push the toilet down to the floor to make a good seal. You will be fine just put some waight on top of toilet to push down wax.
good Luck
Anonymous
  • 999 Answers
  • Posted on Dec 30, 2009
SOURCE: no toilet flange
Go to a hardware outlet(Lowe's, HomeDepot, etc.) and ask for a commode drain extension that can be placed over the existing and bring it up to the level of your floor. I also like the wax rings with the cup molded in. These can be doubled up also but not as reliable as the extension.
Eric
Testimonial: "Thank you very much!!"
cracklin joe
  • 105 Answers
  • Posted on Jan 31, 2010
SOURCE: tiled bathroom floor. Went to install toilet
hi, the tile is supposed to go under the toilet flange (the thing you put the wax ring on), very common "oops", can be rectified by placing another wax ring right on top of the first on. best to make the first one a "horn type" wax ring, then put the plain one (no horn) on top of first and try to smoosh it on just enough to stay in place so when you install toilet it doesn't move,.....cheers!
rmccall59
Robert McCall
  • 51 Answers
  • Posted on Sep 24, 2010
SOURCE: my toto toilet was installed with the seal which
That should work. Sometimes if the space between the bottom of the fixture and the top of the collector ring is too large, (ie: the addition of flooring) one can double up on the wax rings also.
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
Testimonial: "Thank you for your reply re. the wax seal. If we find one wax ring doesn't work we will try 2. Appreciate"
1helpful
2answers
How to fix a new toilet flange so it will not leaked down onto the drain pipe
Hi Connie.
Hoping I'm visualizing this properly. The stand pipe under the house is generally pointing upward and has a flange on it. The toilet will have an indent on the bottom that is somewhat larger that the flange diameter. Then there will be a wax ring that is seated around the neck of the flange right before the toilet is placed down on top of it. The general process is that a new wax ring is placed, the toilet is lifted and, as carefully as possible, lowered straight down over the floor bolts. Once it makes contact on the floor, the toilet is gently rotated a small bit clockwise and counterclockwise to make sure that there is a good solid contact with the wax. The toilet is set square to the wall and, hopefully, with the floor bolts centered on the slots. Someone sits down carefully on the toilet to put pressure on the wax and seal it (this should not be done on a cold day, as the wax may not flow, and may even crack and leave a gap).
From what I saw you write, my questions would be whether the wax gasket was installed. if not, pull the toilet, obtain a gasket, and try again. if one was installed, were the remains of the old gasket thoroughly cleaned away from flange and toilet bottom? if not, the old wax may have cause uneven flow/sealing with the new ring (too much wax in the space).
You can also check that the leak isn't coming from higher up, like at the join from bowl to tank. If it's leaking there, depending on your toilet model, it might leak once the flapper is lifted in the tank, flow down the back outside of the toilet, and down under the house. In that case, it could be a bad seal, or the tank-to-toilet bolts not having been tightened.
Hoping this gives you some ideas
D
Dec 01, 2015 • Home
Olympia toilet fitted six months ago leaks when flushed
Then the wax seal was put on wrong. If the toilet rocks it will ruin the seal. once the wax is squeezed it can't be moved. Sometimes the wrong thickness of wax was chosen. If a new floor was put down the flange may have required a booster kit before putting the seal on
2helpful
What number wax ring do I need?
Most wax rings are standard size. You should pull your toilet off again and scrape off all the old wax. If your toilet flange is below floor level, you may have to use two wax rings, one on top of the other. You can buy rings of different thicknesses, but standard rings should work. When you've placed the rings, place the toilet back on the flange bolts and push down HARD wiggling side to side. When you've got it down as far as you can go, sit on the bowl and wiggle side to side. Repeat this process until the toilet is sitting flush with the floor. NO PENNIES!
or
http://www.homedepot.com/Bath-Toilets-Toilet-Parts-Repair-Wax-Rings/h_d1/N-5yc1vZbl71/R-100139961/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Mar 20, 2011 • Home
3answers
Leaks at the closet flange and we tried many different wax rings.
Hello, W/D here. I always use the wax ring that has the plastic horn molded into it. Rarely, I will place another regular gasket on top of it if the closet flange sits too far above the floor or is cocked. The key to a good seal of a wax ring is to install it properly, and set it several times. What I do is tighten the bolts that bolt the toilet to the flange, and then sit on the seat, putting as much weight as I can on the bowl, and even wiggling a bit. The toilet settles, and I tighten the bolts (carefully) a bit more. I continue to do this several times until the toilet is settled well onto the closet flange and is secure. You have to take your time with this, and be very careful not to over tighten at any one time. You can break the closet flange or at worst, crack the porcelain bowl flange.
Best regards, --W/D--
I will try the hot water/then ice thing. If it is the seal, do you think that three plumbers in a row could get it wrong??? Also about the wax vs rubber seal, which do you think would be better for the...
don't think you r going to get 2 toilet with same problem. I would think you have a broken floor flange instead. rubber seals are great as long as the floor is level and smooth where as the wax seals tend to fill in areas that are not quite level. hope you can get this thing figured out. Toto are great toilets and it would be a shame not want to use it.
When you sit on the ring it veers off to the left and you are left sitting there crooked. How do we adjust it?
See if nuts on studs on bottom where it mounts to the floor & flange are loose. If they are loose tighten both of them evenly. If they are tight you will need to replace wax ring that is between toilet & floor.Turn off shutoff water valve to toilet. Flush once holding down handle to let tank drain. Remove both nuts & lift toilet off flange. Remove wax ring. Scrape all old wax off toilet & floor flange. Install new wax ring. Set down toilet on ring & snug nuts evenly. Sit on seat & apply your weight evenly to distribute wax & level. Retighten nuts. Turn water back on. Allow tank to refill. Flush toilet & check for leaks.
Leak under toilet bowl. Water seeps out from under the bowl. It's not a drip from outside .I replaced the wax ring but no improvement.
1 - Check bolts and washer from the tank to bowl for a leak.It can leak and run down the bowl and pool around bottom of bowl. It will run down the back and under toilet and come out from under bowl in front.
2 - Does the flange sit below floor level some wax ring's differ in size. May take a wax ring with a horn to in the flange, You may try 2 wax rings stacked or get a jumbo size one to get a better seal.
3-Check water line and for possible crack in toilet some where a last resort. Was the flange secure and in good shape, inspect it for a possible crack.
Jun 07, 2010 • Home
Kohller Rialto toilet, can not get toilet to seat properly, leaks from bottom. Tried 3 different wax seals and it still leaks. Toilet was purchased online from Home Depot, and cannot return to store. Same...
If you tried regular sized wax rings and they failed to seal, try using a double thickness wax ring, maybe the space between the floor flange and the toilet exceeds a regular wax ring size. If the floor has been re-tiled and the floor flange was not adjusted this could be your problem, anyhow good luck!
1helpful
3answers
2helpful
2answers
How to Install Toilet
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
