Question about ASUS P4S800D-X Motherboard
Usb are not recognized - ASUS P4S800D-X Motherboard
  • erwinroyo
    erwinroyo May 11, 2010
    Greetings!
    What is th type of your computer? Anyway, if you have the cd installer for your motherboard, there is an option there if you want to install a usb port (in order that your computer can recognize the usb port)
    Thanks.
Posted on Nov 11, 2008
    Problem Solver:
  • 16 Answers
1) Pls go to the setup of your PC and make sure that your USB controller is enable if it is on Disable change it to enable.
2) If it is USB connector in front of your system, open your CPU and check if the cable that connect the USB connector to the main board is well connected both sides.
Johnny
Posted on Nov 08, 2008
    Problem Solver:
  • 6 Answers
Hi...
are u use win98 OS? if yes, u need to update the driver or use the usb driver included on the device you plug in(printer,camera, webcam or flashdisk)
Otherwise, you can upgrade you OS to WinME or Win XP.
Goodluck
Posted on Nov 06, 2008
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
USB DEVICE NOT RECOGNIZED One of the USB devices
This may cause if your USB port is out of order. Or your pen drive is not in good condition.
Think this is helpful !
Aug 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have problem with my usb not recognized.
go to the website and locate where you can download drivers/software, once you have done that look for the specific area and download the driver, or you can go to device manager and make sure the driver is working properly
Jul 16, 2010 | Dell Inspiron 8200 Notebook
Usb flash memory not recognize and become hot temperature malfunctioned
At first attempt in plug in your usb flash memory didn't recognized you may plug out. And plug in again until it recognized you may see that theres an icon in the task bar at right below. Thanx
May 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb device not recognized
I suggest you power off you printer and restart it after some minutes.
You could try another usb to see if it will recognize it.
If the usb is not still recognized, I advice you uninstall the printer driver on your system and reinstall after a while.
If it is not still recognizing it, it means the usb might be bad, you may need to get another usb.
Take care.
Apr 19, 2010 | HP DeskJet F380 All-In-One Printer
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
Usb is not recognizing plug-in
may the usb device in your bios is disable. you must enable the usb device in your bios to recgnice your usb. you must enter to the bios setup to config. the usb configuration.
Apr 30, 2009 | Computers & Internet
My computer dont recognized my mp3 m-230 what can i do ???
mostly, mp3 devices comes with a software.
if u have the software, and the usb dont recognize your mp3 device. most probably the problem is in you usb drive or usb connector.
Feb 27, 2009 | SanDisk Sansa m230 MP3 Player
ASUS P4S800D-X Motherboard Logo
276 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
