Question about A-Top Alien Gaming ATX Case
Help no power
I installed very thing to my new alien gaming case (atx case) plug in after checking things over and over again but no power, not even the power supply fan is going around please help the worst thing is i installed every thing (motherboard graphic card, hard drive ect)?
    Novelist:
    Scholar:
  • 194 Answers
Make sure the wide 24-pin connector cable is firmly plugged into the motherboard. Then short the Power pins on the motherboard with an insulated flat-bladed screwdriver. If the computer powers up then your fron panel power switch needs replacing.
Posted on Oct 05, 2014
Do not use washers unless mobo manual says to use them. Most mobos require electrical ground contact through the seating screws.
Posted on Sep 05, 2008
  • 55 Answers
This is a typically problem when you don't have the motherboard proerly seated. Some part of the board must be touching the metal contacts when you screw down the board to the case which causes a short. Try to reseat the motherboard and also make sure you're using washers in between where you screw down the motherboard to the case. That should fix your issue (Unless there's something wrong with the motherboard all-together).
Posted on Oct 05, 2006
I need a power supply that is compatible for a customers computer
first thing you need to figure out is is it a 20pin connection motherboard or 24 pin connection is it a high horsepower gaming rig or a web surfing machine most PSU's are an ATX form factor got NEWEGG.COM they have quite the selection of power supplies.. hope this helps
Jan 17, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Won't power on is there a fuse
Hi, have you installed everything, I know its the obvious thing but I have bult hundreds of PCs and its always the smallest thing that catches you out!. Go back and double check your connections, even removing every component and starting again is a good idea sometimes. Good luck. (there is no fuse)
Jul 05, 2010 | HP (5065-2501) Mini ATX Desktop Slimline...
Dell Asus M2N61-AX MB front panel connector Nix ATX Gaming case
I assume you mean the HDD,reset,on switch etc where they plug onto the mobo.
Most mobos are labelled on the board but you will need good eyesight to read. They are labelled HDD, RESET, SPEAKER etc.
If not simply look up mobo manual from vendors site. You will need the DELL serial / part number from the old unit though.
Apr 29, 2010 | ASUS Computers & Internet
Ok! I have an ak32 shuttle mother board I'm wanting to upgrade. Over the years I've added newer graffics, audio, extra usb ports,and earthnet card. I built the pc in 2002. I had a cooling fan recently go...
the case isnt amd athlon 2100 xp, thats the processor, the case is either a atx or micro atx case, so refer back to the case and find out if it is a atx case or a micro atx case, then find a micro atx or atx motherboard so you dont have to replace all of your components
Jan 05, 2010 | Computers & Internet
Computer can't boost up
There are a host of things that could cause this. The first thing to check is to mak sure you have the proper memory setup for your motherboard. Often these days you need to install memory in pairs for the board to boot. Refer to your motherboard manual and make sure the memory you have installed is right fro your board and that you have it installed in the right slots. If you do and it still doesn't work, please reply with your motherboard, CPU and memory specifications so I can look into this further.
Jun 18, 2009 | Computers & Internet
I am trying to install Sony speakers on an Acer desktop. I have plugged them in, but they will not work...any tips?
Make sure the speakers are powered , if they have and AC adaptor: the volume on the speakers is turned up so that it's audible. if no power , no amplification.
Here are a few things that you can check to make sure sound is even turned on and drivers are installed:
go to your controll panel, click on system, select the hardware tab at the top, then select device manager.
scroll down to the section labeled "sound video and game controllers" click on the + to expand if neccessary.
if you see a yellow eclamation point ! next to your sound devices' listing , the software (driver) is either not present or corrupt which will cause the speakers not to work. If this is the case , you will need to navigate to Acers' website and download and install the proper drivers for your computer.
check these things and post here again, ill help you with the download process if need be.
Regards.
Nov 20, 2008 | Acer Computers & Internet
Motherboard
clarification request:
be spcific problem like what pin and connected to the......
Jun 26, 2008 | HP Computers & Internet
Just Bought The Mach 4 tried to test it with current power supply
Hi, one quick thing you can check is to see if the cable running from the power switch is plugged onto the right pins on the motherboard, it will most likerly say (pwr btn) next to the pins or something like that, it may also need to be a certain way round.Let me know what the outcome is if no good we can try something else. hope this has helped. Thanks
Onlinepc-Fix
lee
Mar 18, 2008 | Pine Technology Mach 4 KT400ANB...
A-Top Alien Gaming ATX Case Logo
597 people viewed this question
Top A-Top Computers & Internet Experts
Alun Cox
k24674
Are you an A-Top Computer and Internet Expert? Answer questions, earn points and help others
