Question about E-Machines M2000S 15.4" LCD Monitor
Blocked modem when you turn on the computer & go to AOL it tells me the modem is blocked
    Problem Solver:
  • 3 Answers
What is happening with AOL? I have been having lots of pop ups, slow computer and AOL telling me they are having problems? My computer very slow?
Is you computer slow when using software offline? If so, it is either AOL or your internet. Don't judge the speed strictly by going to AOL. Go to Speakeasy Speed Test and test your internet speed. If that shows your internet is running at the speed you are paying for, it si AOL having trouble. You don't say which browser you are using, but most browsers have an option to block pop-ups. Make sure it is on.
Run a virus scan on your PC to see if it is infected. Also defrag your hard drive to speed it up some.
Nov 01, 2014 | Computers & Internet
Modem Casn't Get A dile tone
If you are sure your modem drivers are installed (no YELLOW QUESTION MARKS when you access the device manager), try this;
My Computer/Right Click/Properties/Left Click/click Hardware tab/click Device Manager Tab/click Modem/go to properties/click TEST MODEM---this procedure should tell you that the modem PASSED or FAILED.
If the modem FAILED, it is defective and will need to be replaced.
Apr 11, 2009 | HP Pavilion N5250 (F2362M) PC Notebook
Cant get on to aol 9.1
first call aol technical support ask them to do a diagnostic on ur modem or you can do it manually by cliking on start control panel ,clik ,phone and modems,then clik on modems tab, there should be a modem listed in there if not u need a driver for ur modem if there is 1 double left clik it, then left clik the diagnostic tab,then clik the querry modem tab ,wait ,it will say communicating with modem and then ull see a whole bunch of letters come up if u see them, means modem is good . but sometimes even if it says its good it still could be bad so try a new modem.
Jan 03, 2009 | Compaq Presario 5000 PC Desktop
Can't locate a Modem connection
Ok, First off, Yes, if you have a plug in the back of your computer that allows a standard phone connection wire from computer to the wall, that usually means you have a modem. If you have the ability to get Broadband internet, my suggestion is to get that instead. Its more reliable and doesnt have an automatic disconnect feature that AOL has always had. Also, if you already have broadband, then you can connect with AOL directly through the broadband connection and skip the Modem use entirely. Best i can tell you, other than if your computer is not finding the modem, that means its been either disabled or is missing the drivers.
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Need help
hi,
it doest matter if you have the disk or not. Access the command prompt window, type in "ipconfig" press enter. Make a note of the default gateway. type the same set of no.s in the address bar of the interent explorer, you will acess the modem's Graphical User Interface. If it asks you to enter the user name and password type in user: admin password: admin or leave it blank.
Try to enter the uid and the password from ISP, you should be connected.
krohiti@aol.com
Sep 23, 2008 | Efficient Networks (060-5660-003)...
Modem not recognized
This could be one of many things, but my first suggestion is this.
Open up your Device Manager:
Right click My Computer and select Properties - click on the hardware tab - click the Device Manager button.
Inside your Device Manager check to see if your Modem has a yellow or red icon next to it...
If so open the properties for your modem and click on the resources tab. This page will tell you if the devices IRQ number is conflicting with any other devices.
If the IRQ number is the problem try changing it, then re-booting your computer.....
Feb 22, 2008 | U.S. Robotics US Robotics Sportster 56K...
CAN'T GET AOL DIAL UP CONNECTION TO WORK
This error message normally happens because of a corrupted driver. Reinstall the driver for your modem.If you do not have cd's that came with your computer go too acer's website to download here
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4309542&CFTOKEN=82834010
Now if that is not the cas maybe you are incorrectly installing aol. Start up your aol. If it specifies broadband at login box change to dialup or go to setup and let aol automactically detect your modem. If problem still persists. Reinstall software when prompted make sure you select dialup. Now if you are using broadband and asking for dialup. Or go to the control panel and remove your modem driver, shut down and restart. It should put the modem back.  Any more questions post comment.
Hope this helps you
Oct 25, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
342 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
