Question about Whirlpool Duet GHW9150P Front Load Washer
Soap dispenserther With top removed and viewing top of dispenser there are 4 positions 1thru 4 . My dispenser lever does not go to #1.
  • 63 Answers
The 1st it doesn't that's normal the 2nd time it does "less soap plz" this one stumped me about a mounth ago if ok ther change ccu board under top back
Posted on Nov 15, 2008
Ge potscrubber 700 dishwasher - the soap dispenser cover is locked and will not open. I have run the dishwasher several times and tried to force it but it will not budge. any suggestions?
Soap dispenser cover will not open until front knob is at 4:30 or 5 o'clock. Turn knob to 5 o'clock and jiggle dispenser cover. If cover still does not open, is detergent caked such that door won't open? If yes, remove caked detergent. If no, disconnect power at breaker. GE repair manual says to remove screws for inner door panel and inspect detergent dispenser mechanism with lever and trip lever for broken or binding parts.
Oct 13, 2013 | GE Dishwashers
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
Water comes out of the dey=tergent drawer
Issue, small sock ended up between seal and tub, stopping in front of the hose in front of the soap dispenser. Tools needed, 1/4 inch nutdriver, #20 torx tip and water pump pliers. Remove 3 1/4 in screws from back of top, lift and remove. remove the 2 torx screws, one from top and one from the front in the soap try area. Remove 4 screws screws holding the front frame, pry the entire electronics plastics from the top, one catch on right, one in middle. Remove the last torx from the from of the soap tray, remove the screws to get the metal bracket out of the way. Unclip the 3 hoses and get the soap tray box out of the way. The down hose is where my blockage was, squeeze it at the tub and it will collapse and pull out easy, remove blockage. The hose is not under pressure, just give it a wiggle after putting back in making sure it is round and it will not leak.
And average person with the needed tools should be able to do this.
Jun 29, 2011 | Kenmore HE2 Plus Front Load Washer
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Whirlpool dishwasher DU840SWP. soap dispenser not opening during cycle
Does the washer heat the water during the hot cycle. If it does, your soap dispenser module in the door is faulty. To install, you need to pull power plug out first,then sit on a chair in front of the door and then open the door towards yourself. Once open unscrew those screws along the perimeter of the door to enable you to remove outer panel. Once off, you can view how to remove soap dispenser. If water does not get hot, check the heater element and/or the reset (over temperature switch). Note, top rotator must move freely as well to allow hot water dispersion which on some occasions activates the soap dish. On other occasions it uses a solenoid switch.
Oct 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
He4t dispenser problem soap
Remove the soap tray and clean the orifice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap not fully dispensing
Good you have he soap, powder is not a good option and maybe there is too much. Liquid soap should be no more than 2 Tbls and softner 1 Tbls. These machines use 50 gallons less water than a top loader. If you soap is ok than you can inspect the dispenser. The top cover has three hex screws on the back, ones with a torx use a 9/32 and if not a 1/4 socket. after you pull this cover off, push back and then lift noting a catch is on the front behind the console for alignment at replacement, you will see a white box with a spring loaded cam attached to a arm with a motor under it. Check for lime deposits careful to not loose the spring. Start a cycle and observe for hang ups sometimes a drop of 3 in 1 oil at the dispenser side does wonders.
Sep 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap dispenser
It sounds like the soap dispenser flap is stuck or the latch is broken. Try to see if it can be manually opened to loosen it. How long do you wait before starting the dishwasher after the soap is placed in the dispenser? Check and see if the cover opens even a little during the wash cycle?
There could be a problem with the solenoid that opens the soap dispenser. I don't know of the part number for this. You'd have to call Bosch or check their website.
Mike
Jan 25, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch washing machine
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water enterence and distribution to drawer's cells (following the programmed cycle)are done by a lever's movment (part of the dispenser). The lever movment is controlled by two solenoids that received their power from the timer. By openning upper machine's cover you will have an access to the dispenser. Dissconect the power cable from the machine before moving to next tests !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movment). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Jun 07, 2006 | Bosch Classixx WVF 2402 Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
