Question about Samsung HT-DS400 System
Samsung HT-DS 400
Read normally CD or DVD during a short time(30 second to one or two minutes) then begin to cut the sound some time by jerks.
Thank you for your help
  • azetocom Mar 30, 2009
    I have the same problem...!
  • ca_agostinho May 20, 2009
    I have the same problem. At first I tought it was because of the cooling system because it only started to happen after long time, but now I don't know any more. Like you say, now it may happen after just 30 secs
snakehead
  • 1074 Answers
SOURCE: dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Posted on Apr 03, 2007
chipsandnuts
  • 70 Answers
SOURCE: Samsung HT-TWZ312 surround sound probs
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Posted on Jul 08, 2009
SOURCE: Samsung DVD Home Cinema system HT-Q20 not
i m dvd home cinema sound system ht q20 every thing is ok but soung is not good plz hlep me
Posted on Dec 23, 2010
muntejaya
  • 10421 Answers
SOURCE: change the dvd code for a samsung ht-x250
Hello, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_cvb89i
Posted on Feb 27, 2011
SOURCE: Hi, my Samsung HT-X20 Home Cinema doesn't read
I have same problem but with usb saies Usb Error
Posted on Aug 15, 2011
I have a Digital Home Theater HT-DS400 Samsung. I have problems in reading a music CD or a DVD. You can read the message "Loading.." for a while and then stops and reads "NO DISC". ...
  • Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  • If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  • The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 23, 2011 | Samsung HT-DS400 System
PLAYS CD BUT NOT DVD
hi,
first of all check the spindle motor of ur dvd mechanism. if its winding or the brush short this problem can occur. when u insert a CD it rotates in a slow rpm, but DVD needs a high rpm. if the motor is short it will not rotate in high rpm, and will not read the dvd. normally there will be two types of motor uses as spindle motor. one is dc motor with two wire and the next one is servo motor with five or more connection.
the above mentioned problem will occur only in dc motor with two wire.
Also one another problem is the laser pick up unit. first check the motor, if it has no problem the go fo the laser pick up unit.
ok
Jan 09, 2011 | Samsung HT-SK5 System
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
Samsung bd-p1400 will not play certain disks
My dark Knight DVD was only playing the first 4 screens and I burned the firmware upgrade to a CD. It took about 20 minutes from the time I inserted it for it to be complete, then it stopped at 4 again but took about 30 seconds and it began to play perfect.
Dec 25, 2008 | Samsung BD-P1400 Blu-Ray Player
Region codes
While looking through some forum posts i found the way to fix the problem. It takes a bit of fiddling around but it does work... I tried it out last night.
Firstly you need to put a DVD of a different region into your player and wait for it to start to read the DVD before you commence the procedure... it takes a bit to get the timing right.
when the DVD can't be read it, on screen Eject Disc will come up
Press Repeat & Hold 3 Seconds (it may work using either repeat button on the bottom, i tried both.
Press 76884
After entering those 5 digits, you should see a number in the top left corner of the screen corresponding to the current region (4 being Australia region)
Press 9 for "auto-region" mode ie. Region Free
Turn Off Machine
and there you have it. The timing is crucial so start trying as soon as the DVD is in. It took me 5 goes before it worked.
You will notice that it may take a bit longer for the other Region DVDs to be read then normal but it's only a few seconds longer.
May 02, 2008 | Samsung DVD-V90K Multisystem DVD/VCR
Cant use dvd player, the word lock keeps coming up, dont know how to remove it, the model is a samsung digital home theater system HT-DM150
i have a samsung dvd theater system ht dm150 it will sometimes read the dvds dut majority of the time it wont read any dvd i even used a cd cleaner on it. 80% of the time it will play music cds.
Apr 21, 2008 | Televison & Video
Dvd does not load
Apr 03, 2007 | Samsung HT-DS1000 System
PROTECTION
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Jan 02, 2007 | Samsung HT-DB120 System
Samsung HT-DS400 System Logo
75 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
