New HD TV (Samsung)is conncted diectly to the cable jack in the wall. There is no box, vcr or dvd. Wehn selecting some channels (for example channel 4, it comes on but after a few seconds the video goes away. If I select channel 4.1 it works fine. Samsung says the problem is not them, cable says the same. The store where I purchased the TV says the problem is some stations boadcast both analog and HD and there is no solution. I don't buy this. Is there a fix for this?
  • gerrygibson Nov 06, 2008
    the solution did not work
  • gerrygibson Nov 09, 2008
    The vcr/dvd player works otherwise. Now I am wondering --maybe a dumb question--but I don't know if the vcr has a tuner; it is just the standard vce/dvd player
    Sergeant:
  • 229 Answers
Most VCR have tuners. Pick menu on remote then hit auto-program to initiate tuner. The you might be able to solve by routing through your VCR as suggested. Good Luck
Posted on Nov 09, 2008
    Genius:
  • 1,239 Answers
Hi it is vcr problem change it
Posted on Nov 06, 2008
    Sergeant:
  • 306 Answers
It only happens when using DVI/HDMI digital video connection.
It doesn't happen with component (Y, Pr, Pb) connection.
Digital video connections are not a perfected technology.
  • AbdulRahiman S Nov 06, 2008
    Try switching back and forth from 480p to 1080i, and see how your HDTV behaves. first Turn-off the upcoverting of your HDTV so that it is trully 480p and 1080i ..
  • 749 Answers
Not a fix , but a work around, run the cable through a vcr or dvd player that has a tuner in it. Use the AV OUT feature of the vcr/dvd player into the component IN on the tv, this should lock it into an analog signal.
Keep in mind that when your cable provider goes totally digital, you will need to revise this setup to accomidate the full digital.
Posted on Nov 05, 2008
  • 19,396 Answers
It is the cable signal that is too high in intensity.
  • Ginko
    Ginko Nov 05, 2008
    The cable signal is measured in decimals per millivolt dBmV, and must be between 10 dB and -10db, at -10db the signal get fuzzy, over 11db the tv shut down.
    The cable on the wall is connected to a cable decoder main box, this may be responsible for the bad signal.
    Additionally if the horizontal cable lines (the ones that start from inside the wall), are bad that may also be a problem, in that case you need to replace the cable.
    A possible solution to your problem is calling back the cable company and asking them to replace the cable line.
  • Ginko
    Ginko Nov 06, 2008
    The solution is testing and eventually replacing the cables that go into the wall, as I already told you.
    This job must be probably done by the cable company, call them and tell theme that this had been our response.
    If the image is fading then signal on cable is probably less than -4db, somebody must take a multimeter and testing cable output signal.
    Obviously you cannot expect to fix this by pressing buttons on your TV and similar, as the problem is concerning the final cablature of your lines.
Bought new samsung dvd/vcr. have an older admiral tv with just a cable hole. this is the second tv on a dish network, so this tv only has a cable, the box is in the living room. so how do I hook this...
The easiest way to make it work is to:
1- run your cable into your new VCR to CATV IN.
2-Your VCR should have come with a short length of cable. Connect it from the OUT jack to the TV.
3- Set the TV to either channel 3 or 4- you need to check the VCR manual to see which channel you have to use. Some VCR's have a small switch labeled "channel select"- if so, set it and your TV to the same channel... your choice.
4- Leave your TV on the channel you set above all the time. You will now change your channels using your VCR. You will be able to record whatever you are watching.
Feb 12, 2011 | Televison & Video
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
Samsung DVD-VR300 - cannot get VCR or DVD to play
cable from wall/outside to cable box in, cable box out to dvd/vcr in ...dvd/vcr out to tv...........set both tv & dvd/vcr to Ch 3.........
note you will not be able to record (probably) HBO on to DVD (vcr yes)
Jan 31, 2009 | Samsung DVD-VR300 DVD Recorder/VCR
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Hooking up DVC/VCR to HD cable box/TV
Hi Seve.
Not sure what is meant by 'HD cable box'.
If you mean a DSD (Digital Satellite Decoder), then the built-in firmware prevents recording (of composite video signal).
In our country the SP requires that you buy a dedicated 'Explora' decoder which allows recording.
HD cable technology may have introduced similar anti-piracy measures.
{reminder to me: Google "HD cable TV" :)
Oct 06, 2017 | Televison & Video
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
GO VIDEO DV2150
you can try going from the wall to the dvd/vcr first then to the cable box then to the TV. It may find the channels but they might not be in the order you usually wouls see them i.e chan 4 may be chan 34 etc. this will only work on an analog connection, if you have digital cable box it will not work. other than that, you have to control everythng from the cable box and the dvd remains on chan 3 at all times.
Sep 25, 2007 | GoVideo DV2150 DVD VCR
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
