Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027 What is the part number or option called for printing? Do I need a HDD or extra memory? Thanks, Claire
  • Anonymous Mar 14, 2014
    ricoh 1027 print scan
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
There are two possible options:
Printer Module (B461)
This requires the 64MB memory option (G579).
Printer/Scanner module
This requires the 64MB memory option (G579) and the NIB (G574).
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
Aficio 1027 only print first couple of pages
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Afico 1027 Printer not printing all the pages
I haven't seen such problem in this printer
Anyhow uninstall the printer software and reinstall it
You might have PCL6 driver
Try RPCS Driver from Ricoh Web
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh aficio 1027 with fax option and i want change the recieve function to auto answer with 5 rings
1. Download driver from http://support.ricoh.com/bb/pub_e/dr_ut_e/0001153/0001153018/V3100/r29694en.exe
2.If that doesn't fix the issue immediately try http://support.ricoh.com/bb/pub_e/dr_ut_e/0001154/0001154861/V861/r30275en.exe
Sep 11, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027 what is the scan option part number?
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
Oct 07, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Discontinue fax transmission report
Press;
  • User Tools/Counter button
  • Facsimile Features
  • Key Operator Tools
  • Parameter setting
  • Select Switch No. 03
  • Select Bit No. 5 for Immediate Transmission and
  • Select Bit No. 0 for Memory Transmission
When the Bit number is pressed, the current value switches between 1 and 0.
Please set these two Bits to 0 to disable printing of transmission result report.
Then press;
  • OK
  • Exit
  • User Tools/counter button
Jan 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
White vertical lines on printed page
change the k black drum... its the only solution trust me
thanks
Nov 19, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
128 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
