Question about Unitech 630D PDT 2.5MBRAM LR CCD SCA
Display when I turn on the scanner
This is what I see when the scanner turns on. Help please!
PT630 BIOS V1.93 MEM 512
I have pushed all the buttons more than once and I cannot ge the scanner to give me the main screen. Thanks for any help here.
  • 155 Answers
Anne834: Press and hold the CMD botton.
Roberto Martinez
padrino99@prodigy.net.mx
Posted on Aug 28, 2011
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
How do you set the clock on a milwaukee radio
turn the radio on, push the MEM button display window will flash turn the tuning knob clockwise to set hours and counter clockwise to set minutes push the MEM button and hold 5 seconds to set time. Hope this helps, if I have solved your problem would you please vote accordingly and thank you.
Jun 10, 2011 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
MESSAGE PT630 BIOS VI.94 MEM 4608 KB WHAT SHOULD I PRESS TO PUT IT ON SCAN MODE? (READY) THANK YOU
Press and hold CMD button. Then, option 8 for settings, option 2 for scanner. Use arrows and enter key to select your preferred settings from there.
Feb 02, 2011 | Unitech PT630 Portable Terminal
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
My sony Vaio has been upgraded to 2x 512 mem from 1x 512 plus 1x 256, which recognised as 768, it will not recognise the exra mem, both 512 m are kingston PC 266 should be compatable with the comp, any...
Yes if the FSB is not the same you can have this complex mutual,necessary if the FSB is 266 should be included is the 266 also, although it is both same MB size.may also be secondary to that are other video memory you please check the BIOS settings only.I already help you and them good luck only, good day.
Oct 22, 2009 | Computers & Internet
Unitech pt630d reset code
That message which your scanner is displaying is the normal and correct mode in stdby, there is no problem with it.
If the scanner says "bad command" is because you are pressing the "enter" (ENT) key without any command selected before.
Bye.
Feb 12, 2009 | Unitech PT630 Portable Terminal
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Unitech PT630 files
What program are you trying to replicate? Is it a third party application? What error you received on the PT630 screen when u run the program.
Dec 30, 2006 | Unitech PT630 Portable Terminal
Unitech 630D PDT 2.5MBRAM LR CCD SCA Logo
120 people viewed this question
Top Unitech Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Unitech Office Equipment and Supply Expert? Answer questions, earn points and help others
