Question about Epson Perfection V350 Flatbed Scanner
EPSON 350 scans 1/2 photo, makes loud clicking noise.
My scanner is making lots of noise sounds like it might be off the track. It'll only scan half the photo then smears the rest. Can I fix this? What's the best way to fix this?
  • Anonymous Jan 09, 2009
    Mine does the same thing and I have no idea how to fix it.
Service required for epson 350
Posted on Jun 16, 2009
The chassis bends very easily on this model and the problem can be caused by scanner not being on a level base supported by all its feet.
Posted on Apr 14, 2009
My Epson 1240 has just stopped scanning the bottom half of the flatbed. It makes a crunching noise and goes back to the top.
The Track/chain that the scanner bar follows might have some debris/dirt whatever on it stoping it from moving further. Alternatively the motor might have a problem. you can take the cover off and blow that area with a con o' air. Make sure not to get dirt or prints on the scanner or the bottom of the glass
25630969-kdbydlvhgx3mczs4yctz3wk3-5-0.jpg Basic idea of most scanners
Apr 06, 2015 | Epson Perfection 1240U Flatbed Scanner
Scan the film sound "ka!ka!ka!" from the top light box, and the light box stop at 1/4 position. As the result, the scanning picture over exposure. Leo
Some scanner prescan, if the object is only 1/4 of the size of the area this is normal. If not you have tracking problem.
Aug 13, 2014 | Epson Perfection V700 PHOTO Flatbed...
Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Apr 07, 2010 | Epson Office Equipment & Supplies
My scanner makes a loud noise on start up what is it ?
It is normal for your Epson scanner to produce noise on startup as it calibrates the motor that moves the scan mechanism when powered on. But if this is too loud than normal, it means that there may be already a problem with the motor and must be replaced if it wouldn't give out quality scans. Otherwise, it is working normally.
Nov 06, 2009 | Epson Perfection 1660 Photo Flatbed...
Epson Stylus NX105 scanner started clicking when turned on...
I dismantled the printer because i've been having the same issue. It recedes to the right and begins clicking because it is at the end of the track. For some reason the scanner isn't registering that it is at the end of the track and keeps persisting making the gears jam up on the other end because they obviously can't move any further. Any suggestions as to how to fix, or master reset?
Aug 28, 2009 | Epson Stylus NX105 All-In-One Printer
My scanner :makes a loud noise when trying to scan or copy
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I need more information to offer a definitive solution, but I can give you some information that might help diagnose the problem.
Unless you forgot and tried to use it locked…then unlocked it after, it seems unlikely that changing the ink could directly affect anything related to the scanner. So especially if it still scans and now just makes more noise then before, we can reasonably say it isn’t a faulty locking mechanism and that the gears are probably not stripped, which would either stop it or not. So you’re looking at either something simple like the gear assembly being dry, shifted slightly, etc. or the safety by the lock that makes noise to tell you the device is locked is stuck somehow. The one can be tested by removing the little plastic safety that makes the noise when the scanner is turned on and locked; the other you might be able to test with some WD40 and see if it runs quieter.
Aug 24, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Apr 15, 2009 | Epson Perfection V100 Flatbed Scanner
Epson Perfection  V350 Flatbed Scanner Logo
741 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
