I have a 18" yard machine with a 208cc OHV. I ran the macine for 15 minutes, stopped the motor, turned it on end to look at the tines, turned it to the run position and the motor would not crank. Pull the cord and it stops hard, removed the cover from the opposite side of the motor and turned the nut center of the shaft, it stops hard.
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
SOURCE: I just purchased a troy
remove the spark plug. And pull the cord again. if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine. Check.
SOURCE: Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
SOURCE: Rototiller pull start won't pull
First thing to do, if you haven't already, change the oil, and remove all 'old' gas.
Then, after that's done, remove the plug, in order to de-pressurise the cylinder.
Then try to crank it again.
If it turns, then clearly, it's not ceased.
Remember, don't loose you're patience, just take your time.
Good luck with that:)
SOURCE: Yard Machine rear tine 6hp tiller that wont start.
Ok, what's happening, is your carburetor metering hole is plugged. When you place your thumb over the carb, it draws fuel through the primer circuit to feed the engine instead. What you need to do, is clamp off the fuel line, take the nut off the bottom of the carburetor bowl, and clean that nut. Look closely at it; there is a hole that goes down the center of it, and a hole that goes through it side to side towards the bottom. These make a "T" shape inside the nut. You need to make sure that these are completely clear and clean. The one at the bottom is very small, and plugs easily. You usually need a small piece of wire to clean it, such as a single strand from a wire brush. You can use carburetor cleaner to loosen it up a bit, but the important part is to clean that hole out. You also need to make sure that the float moves freely up and down while you're in there. If it sticks in the up position, it will starve fuel as well. Also look closely at the gas that came out when you did this. Was there any water in it? If so, let a bit drain out before putting it all back together.(unclamp the fuel line). Hope you have it back online soon.
Testimonial: "Nut was clogged. Now it starts but acts as it is in choke position, dont think there is a choke. Engine reves, falls, reves falls but stays going."
