Question about Dryers
FV-11VQ3 panasonic fan is not working properly
We have just installed the fan and even if we stand underneath it and blow smoke into the fan, it sucks air very lightly - something clearly is not done right during the installation
I called panasonic and they said to take a look at the damper to make sure it is opening, as well as the ventilation flaps on the outside
but he said in order to get to the damper I have to remove the unit - is there an instruction guide a how to - or will I find it straight forward - if you could let me know I would really appreciate it
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are there any filters on the unit?
  • 2,794 Answers
I found this installation manual:
http://lib.store.yahoo.net/lib/rewilliams/fv05vq3.pdf
There are detailed pictures of the whole fan assembly in it.
Posted on Nov 07, 2008
I dont believe there are any filters - I looked outside and the flaps were open and also looked like the damper was fully open - so not sure why it is not as powerful as I thought it would be
Posted on Nov 06, 2008
My quiet bathroom fan makes a roaring noise
The roaring noise is probably the fan blades (looks like a hamster wheel) are worn out as it rotates on the spindle/shaft.
It may be a problem with the 4" exhaust ducting, that connects to the exit part of the fan, has come loose. Theres a damper (kinda like a flapper) at the fan/ducting joint may have broken off and may be sitting sideways in the ducting flapping around inside the duct.
At any rate I highly doubt its wiring. Sounds like its time to pull the fan cover off (turn the power off first via the wall switch or the service panel breaker would be even better) and look at the fan blades. Clean off any dust bunnies, lint, etc. and turn the fan back on. Did the noise stop?
If nothing looks out of place and it still makes noise you'll have to get in the attic and remove the ducting from the fan and see if theres a problem at the connection there. Maybe a squirrel put its bedding in the ducting? It happens.
Could be lots of reasons for the noise but wiring it wrong wouldn't cause roaring. The fan wouldn't work, or worst burn up, if wiring was the issue. The problem is the more than likely the fan blade assy is worn out or something is restricting the air flow in the ducting going to the outside of the house.
Nov 19, 2012 | Panasonic WhisperCeiling Bathroom Fan...
FAN DOES NOT GO ON AND CAN THE FAN MOTOR JUST BE CHANGED WITHOUT REPLACING THE COMPLETE UNIT ??
Yes and maybe.
If you open unit, usually fan motor is plugged in, and motor is removable with bolts.
The problem is finding new fan that fits same housing without spot-welding and drilling.
I did google image search for "replacement vent fan motors" and results show choices.
For example Nutone:
http://nutoneproducts.typepad.com/nutone-products/nutone-bath-fans/page/2/
If you can locate same brand vent at local box store, you can use parts from new one to repair old one without project of replacing fan housing.
20 years ago, motors went to electric repair shop and they rewound the motor.
But today, motors are landfilled or shipped overseas for recycling.
All costs are energy, and right now, cost of re-wind is more than buying new motor, or new vent.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on fan or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2011 | Panasonic WhisperCeiling Bathroom Fan...
Replacement bulb for Panasonic FV-11VQL4 fan doesn't fit
It' a unique bulb that is available online. The big box stores don't carry it.
Oct 23, 2009 | Panasonic FV-11VQ2 Fan
Cleaning the blades
An air compressor would work. It might be a bit too powerful for it.
Those cans of air they sell in office supply stores might work too.
(Previous message was posted as clarification, not solution).
Jul 14, 2008 | Panasonic FV-11VQ3 WhisperCeiling Ceiling...
Odors are backing into the bathroom after installing the whiperfit
try to install the fan at a lower height so that it can drive out all the smoke. This is because the fan can driveout air with in a certain radius and installing it at a lower height increases it..
Jun 16, 2008 | Panasonic FV-05VQ3 WhisperCeiling Fan
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Feb 25, 2008 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
Dryers Logo
362 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
