Question about JVC TH-C30 System
JVC THC30 no subwoofer power = no sound
I have had this system for some time now. The subwoofer just refused to power up at all one day! Everything else seems to be working correctly, including the dvd player! But all the speakers plug into the subwoofer. The subwoofer just doesnt power up! Yes i have power to the outlet! Does anyone know what the problem could be?
  • adamsbri May 25, 2009
    Same problem bro. Have you been able to fix it since?
    If you know how to fix it please email me at adamsbri@live.com. I would really appreciate it! thanks
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: My JVC THC30 subwoofer won't
If you're saying you have a defective subwoofer that keeps the system from coming up you might find one on eBay. many owners of HTIB's sell off the remaining bits as parts die off.
Or maybe your subwoofer comment is not related to your power problem.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 18, 2011
My JVC THC30 subwoofer won't power on therefore no sound since all the speakers run through it. How can I fix this or is there a way to replace just the subwoofer?
Apr 18, 2011 | JVC THC3 Home Theater System System
I have the sub woofer and two sp-thc5f front speakers. Can I hook this subwoofer directly to my JVC 56 high def big screen or do I need a dedicated amplifier that works this sub wooofer?
No, the powered subwoofer gets its signal AND power through the DIN connector so you'd have to second guess JVC engineers on which pins are power or signal; and what voltage level it supplies and then you'd have to come up with a source for the power. Managing the volume and relative levels would be a trick, too. Devastation lies down that path.
Get the prescribed JVC electronics or go with a whole new sound solution.
Jan 16, 2011 | JVC THC5 Home Theater System with 5-Disc...
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Looking to purchase powered subwoofer
You can order the Subwoofer of the JVC website.
www.jvcservice.com
It have all subwoofer.
May 01, 2008 | JVC UXG70 Micro Audio System Shelf System
No power to speakers
sounds as if the internal fuse as gone look and replace ?
Dec 22, 2007 | JVC TH-M303 System
Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Oct 14, 2007 | Audio Players & Recorders
JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Aug 25, 2007 | JVC TH-A10 System
Subwoofer won't turn on
try and see if it as internal fuse ? if not the bad news is that possibly the amp as gone
Jan 01, 2007 | JVC TH-M303 System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
JVC TH-C30 System Logo
142 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
