Question about Sony ICF-SW7600 AM/FM/SW Radio
No tunning Hi, i stored the radio for a long time and when i desided to use it , the tunning problem came out, i can not lesten to any radio station. thank you and forgave me for bad writing
  • 1 more comment
  • Anonymous Mar 08, 2008
    how increase the gain of tunned station
  • Anonymous Jul 10, 2008
    no ino have problem now. I need service manual of this item sony ICF SW600GR
    auguvipe54399@gmail.com.co.
  • mike53952 Oct 05, 2008
    I have a Sony ICF-SW7600. After not using it for while (the batteries and AC adapter not connected) I cannot receive the AM Broadcast Band. However, I can receive the FM and Shortwave Bands.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Hello Hammad, I think you should try and resolve the problem by buying a new radio. It's probably broken. My heart is with you my friend.
Posted on May 08, 2007
SOURCE:
How do I change the time on a Timex T235 Alarm clock - can't find my book
To set the clock on the T235, make sure that the radio is off. If the radio is playing, press and hold the Power/Mode (the left-most button) until the display briefly shows Off and the time is displayed. Press and hold the Clock button (the center button), the display should start flashing. While the display is flashing, press the Tun + (Hour) button, next to the Power/Mode button, to advance the hour to the current hour. Then press the Tun - (Minute) button, between the Tun + and Clock buttons, to advance the time to the correct minutes. Then while the display is flashing, press Clock and hold to exit the time set mode. This will start the clock.
Timex has the manuals for many of their clock radios on the product page or their support page, https://timexaudio.com/support/ . For the T235, the direct link to the manual is https://timexaudio.com/media/uploads/product/files/T235_User_Manual.pdf . See page 6 to find the directions to set this model.
I hope this helps.
Nov 06, 2016 | Timex Audio Players & Recorders
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
29 LTD CB Radio: Hi I am from Romania and I have a Superstar CRT 2...
yes you can do this.its called a variable power switch .
May 18, 2010 | Cobra 29 LTD CB Radio
How do u get a code for the radio so that u can tun it on and liste to it
hi...
These becker radios can be difficult if the wrong codes are entered( i think if u enter 3 times in a row) and it goes into security lock.... if you enter code and it does not work remove radio and get serial number of and call dealer. The way you enter 4 digit code is by entering the number with the station program keys on the top of the face plate ,, then after code is entered you press the * symbol and it should start working. There is a becker web site that can also assist you with radio problems it is www.beckerautosound.com .
hope this solution will solve ur problem
thank u
Aug 23, 2009 | 1992 Honda Accord
Having major issues with programming my bearcat bc60xlt-1
You'll need to program the radio frequencies into your scanner before it will scan . For a list of frequencies in Anoka County CLICK HERE .
For specific programing instructions for your UNIDEN refer to your owner's manual. They will give you a step by step instruction on how to program the frequencies into your scanner memory (If you need a manual, CLICK HERE
...be sure to select the scanner option on their pull-down menu.
THEN when you have the radio frequencies stored into your scanner, you'll be able to press scan and away you go.
Be sure to adjust the squelch just high enough to eliminate the static...turn the squelch counterclockwise until you hear loud static, then turn Clockwise just enough to silence static...
Let us know if you still have trouble.
Jul 20, 2009 | Uniden BC60XLT-1 Handheld Scanner
Setting radio stations
The solution for setting the radio station on a Pioneer DEH P2000, is to tune the station you want programmed and hold down the desided channel number until the program number appears on the display.
BC
May 23, 2008 | Pioneer DEH-P2000 CD Player
Time set and LAP
With the radio turned off and displaying the time, hold the MODE switch until the time display flashes (about 2 seconds). Release the MODE switch then quickly, use the TUN (up) to set hours, TUN (down) to set minutes.
Oct 06, 2007 | Koss PP257 AM/FM Radio
How to set Stations
u set up the channel u want with "tun.up"\"tun.dn" press the "mem.ch" for five sec untill it flickers or beeps now u know its in the memory do so 4 any station u want
Feb 01, 2006 | Jensen SAB-55 Radio
Sony ICF-SW7600 AM/FM/SW Radio Logo
112 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
