Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman door opener
Press button and door closes and then opens back up on its own
Does the door touch the floor? If so your down limit needs to be decreased.
Does it open back up mid-travel? If so your down pressure needs to be increased.
Read your manual about setting the safety reverse system if you change any settings.
Posted on Nov 05, 2008
I have a Craftsman opener with security plus (18 months old-blak transmitter button) and the wireless keypad will open the door by simply hitting enter (no code required). I would assume it had to be the...
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Aug 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Okay, I'm having an issue with my Sears Craftsman garage door opener. Not exactly sure of the model number, but can dig it up if that's necessary. Symptoms: 1) Door opens fine from either wall button or...
It sounds like you have a problem with your wall button. I would remove the button from the wall and then disconnect the 2 wires on the back. Remember where they go as they are color coded. You can then momentarily touch the two wires together to check the operation. There isn't enough voltage there to bother you.
One thing to remember. If when the door reverses the main light flashes 10 times it is a door sensor problem and nothing else.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage door opener does not open or close
The drive gear is most likely stripped. It is a white nylon gear just in front of the motor. The parts number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garrage door opener ability to close the garrage door
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman remote -- new battery installed..
close the garage door, press the lock button so that's it's blinking, press the red reset button on the craftsman, then press the remote.... that should work
Feb 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
80 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
