Question about Mitsubishi VS-50705 50" Rear Projection Television
Tv seems to need to warm up
About a week or two ago my tv seems to need to warm up. When i turn my tv on after it has been off for a period of time it will turn on and i can hear it fine, but there are jumpy lines and and it is like spazzing out. After a few minutes it is fine. Just like it needs to warm up. Please give advise on what problem is and what i should do. Im pretty raw at stuff like this all help would be greatly appreciated. Thanks
  • dc_12_88 Sep 24, 2008
    I have the same problem with my samsung 2032mw sycmaster hdtv.When i turn it on after it's been off for a few hours the picture doesn't show up at all then when it eventually comes on the picture keeps flickering on and off.After it has done this for a while the picture stops flickering and is as it should be.I am quite annoyed as i have only had this tv for around 6 months.The other day it took 20 minutes to come on.
    Any Help Appreciated
  • 65 Answers
The previous posters pretty much smashed it in the mouth im pretty good with subminiature surface mount caps and repaired the mitsu pip modules since they are no longer available for replacment dont try this at home kiddies pull the pip module ( its the one with the blue connector standing up on the main pcb it uplugs like a computer board oh theres the c word again any way if you can find someone to jump thru the video and audio on the connector of the pip board you will loose a useless feature and gain video and audio back to the tv two 4.7 uf electrolytes from like pin 2-7 1-8 or sumthin like that thats somewhere in the internet galaxy warning i have seen these sets with bad tubes if you turn off all ambient sound in a dead quiet room and hear arcing or snapping noises this set has a high voltage leaks somewhere and suspect bad crts mottos...Mitsubishi, we're still building Zeros ok.. you have questions we dont have any answers 73
Posted on Dec 09, 2006
    President:
  • 3,130 Answers
This is a pretty commom problem with this model. As it has several bad capacitors that go bad. If you have no solid state repair experience, and to save you from any high voltage shocks that can kill you, i would highly advise you to contact a local authorized repair shop to assist you in the repair of this set. As much as you really want to repair this set yourself, To do so would be tempting faith! As a Tv set these days are all solid state and have no user serviceable parts inside of them and to try and experiment with them, could be very harmfull and a risky thing for the user to do. Please find a trained tech to assist myou in the repair of your set. Good luck , and please report back on how the set was repaired.
Posted on Oct 05, 2006
    Problem Solver:
You don't state your model and this site indicates you don't have to but for other regular Joes' like myself it helps. Some of these problems/solutions show up under many models of the Mitsubishi line. Now there are several "chasis" in these sets. They are VZ6, VZ7, VZ8 and VZ7+ that mine has. If this is a Mitsubishi model VS-50705 or one of the others built in 1999 they have like the other tech informed some bad electrolytic capacitors around the PIP circuitry on the "signal board" where it connects to the "main board". The other tech is correct. If you don't know about power you could get hurt. But if you are like me and know enough to do some basic things then here is what Proton1000 gave me and my set had the same thing and it got worse. You have to replace the electrolytic capacitors (C2P02 47uf 35v), (C2P03 100uf 16v), (C2P04 47uf 50v), (C2P05 100uf 16v) and (C2P08 47uf 35v). These are located around a heat sinked voltage regulator IC2P01 (9v IC regulator). You will have the same setup if your "signal board" contains the PIP IC (IC6P01). There are 2 square little boxes on the "signal board" that have removable tops. One is solid the other has holes. The one with holes is where the PIP IC is under so you can identify if you have the same board. Some have a PIP board on the "main board" and I've seen recommendations to bypass the PIP by adding capacitors to a connection under the "main board" VG plug. I think it was on this site also. Now my initial problem was solved but now I have a little color/bright white color going on the main feed. The sub PIP feeds look great. So I've opened a case here hoping the guru's can help. I suspect another capacitor or other minor component. And you won't find these capacitors at your local Radio Shack. They don't carry crap anymore like the old days. You can go online to this site in Atlanta and then call them and order over the phone and they will have anything you would ever need in electronics. acksupply.com
Posted on Dec 08, 2006
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
46 inch Samsung HD clicks but won't turn on. First notice several weeks ago when using remote to turn on tv, it would click a few times and come on. Over a period of time, it would click for longer...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 25, 2011 | Televison & Video
Monitor will not turn on blue light flashing bottom right hand of monitor
I'm having the same problem. Had the monitor for almost 2 years and everything was working fine until this week. The blue light would blink, then after an unpredictable period of time, the monitor would turn on. Seems like it needs to warm up or something. I suspect it has something to do with the capacitors not charging inside. Somewhat disappointed with Sceptre. I suppose I should be thankful that I got 2 years out of it.
Oct 09, 2009 | Sceptre x22wg Gamer Monitor
97 Jetta won't start
tyr disconnecting the temp sensor unit and try starting it
Jan 01, 2009 | 1997 Volkswagen Jetta
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Hard time turning tv on and once on, will turn off after a period of time
Sounds like it may have been jarred or theres a larger tall capacitor in the power supply that goes bad in these sets alot. Its not something a layman should attemt. As a matter of fact the only thing in this set that is user replaceable, is the lamp. Sorry but your going to need the service manual and soecialized tools tom trouble shoot this set. you really should seek out a pro for this repair.
Sep 12, 2006 | Panasonic PT-40LC12 40 in. LCD Television
Sony 36" tube TV
It definitely does not seem to be a problem with the Picture Tube. More like a cold solder. It is definitley not a job for a layman. Also, get a good technician to have a look, as locating cold solders is a labourous and time consuming process. It could also be possible that the main DC filter capacitor is getting dry, and may require replacement.
Aug 15, 2006 | Sony KV-27S20 27" TV
Mitsubishi VS-50705 50" Rear Projection Television Logo
1,566 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
