Question about HP LaserJet 1020 Printer
Print spooler service not running
Although plugged in to my computer, when i try to print it says i need to add a printer & that the print spooler service is not running. windows xp professional
  • Anonymous Dec 03, 2008
    Printer spooler not working
  • Anonymous Jan 12, 2009
    Guru:
  • 558 Answers
This means your printer is not correctly installed. Please remove the installed driver and printer from the PC and then follow the steps given in this TIPs N Trick by me:
http://www.fixya.com/support/r1133275-drivers_installation_problem
Posted on Nov 04, 2008
Please send solution asap. thanks.
Posted on Dec 10, 2008
I cannot print my documents, everytime I click the printer "print spooler is not running". I already restart my printer as well as my computer. And I also tried to reinstall my printer but it doesn
Click Start.
Type services.msc in the start search box and press enter.
Right click on print spooler and click on properties.
Check if the startup type is automatic. If it is not then change it to automatic.
Check if the service status is stopped.
If yes then click on the start button.
Try to add a printer and print a test page.
If you need any technical help on printer then you can reach at here
Jan 25, 2013 | Office Equipment & Supplies
A print job, although cancelled, doesn't leave the printing list.
Please try this approach:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 24, 2012 | Lexmark X1270 All-In-One InkJet Printer
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
Printer spooler
Resolution:
Mar 13, 2011 | Canon Office Equipment & Supplies
I'm getting the error message whenever I try to select a printer that ''Windows can't open add printer. The local print spooler service is not running. Please restart the spooler or restart the...
If u r using the XP operating system, follow the steps to restart the spooler :
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Start.
May 08, 2010 | Office Equipment & Supplies
Print spooler not running
For XP use the Control Panel then Administrative Tools then Services. Make sure the Print Spooler service is running. If it is, stop it then restart it and try installing your printer again. :)
Jun 23, 2009 | HP OfficeJet 4255 All-In-One InkJet...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
SPOOLER SERVICE IS NOT RUNNING
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
HP LaserJet 1020 Printer Logo
190 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
