When i press shift and the number 2 i get " how do i fix it?
    Master:
  • 409 Answers
You seem to have your PC set to a UK keyboard. Look in the bottom right hand side of the bar at the bottom of the screen. if you can see EN in white writing you are set to UK. Click on it and select US. If not then let me know and I will let you know other ways of changing it.
Posted on Nov 04, 2008
I have casio fx-100MS and want to bring its default settings
Press "SHIFT" then "MODE CLR" followed by number "3" and the "=" key two times.That fixes it.
Apr 16, 2012 | Casio Office Equipment & Supplies
Tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
on Nov 11, 2013 | Microsoft Excel Computers & Internet
CASIO fx-82MS: How can I erase the "Eng" sing that appears in the screen (I tried the "ENG" key and it did not work) ? thanks
Hey I had the Similar Problem, which got solved as I happened to refer to the Quick Reference specified inside the Calculator cover (FX-82 ES). Press the SHIFT and CLR buttons for a while and then select 2(Mode) and then press the ' = ' button. The ENG sign disappears!!! Well Hope it works for you and others too :)
Sep 23, 2011 | Casio fx-300ES Calculator
How to use the this " @ " key on dell vostro 1015 laptop ?
This can be a little tricky. You will need to hold down your "Shift" key located below your "Enter" key and then while holding that key down press the number 2 above your "Q" and "W" keys. This handy little trick can be used to access any of the symbols located on each of the number keys.
Sep 15, 2011 | Dell Vostro 1015 Laptop
How to key @ on the keyboard, only able to get " instead of @
Press the shift button while pressing the number 2 on the top row.
Mar 12, 2011 | HP CPQ175KB Keyboard
What function should it be on to get a whole number answer for division problems EX: 15 divided by 2
15 divided by 2 isn't a whole number.
If the calculator is showing a fraction and you want to see it as a number, press the S--D key to switch between symbolic and decimal values. To have all results appear in numeric form, press SHIFT MODE 2 to select the LineIO mode.
If you want to set the calculator to show only whole number, press SHIFT MODE 6 0 to select FIX 0 display mode.
Feb 22, 2011 | Casio FX-115ES Scientific Calculator
HOW DO YOU DO NEGATIVE 10 POWER NUMBERS LIKE 2.5 X10-2?
Hi ceanelson,
First, I would clear the memory. Press [SHIFT] [9] (CLR) [1](Setup) [=] (YES). Then press [SHIFT] [MODE] [2] to switch to the LineIO mode. Put the calculator in Norm2 mode. I just like the way it display these kind of numbers in Norm2 mode. Press [Shift][Mode] [8] [2] for Norm2. Next check make sure FIX mode is greater than at least 5. I usually select FIX 9 but, 5 seems to be good for must non-essential calculations. Next, press [2] [.] [5] [*10^] [(-)] [2] [=]. You can use the [SHIFT] [LOG] for the 10^ and, I usually do instead of [*10^] key.
Next, when dealing with numbers like these, I always use brackets. Such as press [ ( ] [2] [.] [5] [*10^] [(-)] [2] [ ) ] [=]. This is because, if you divide or do some other math operation you want to keep this number as a whole complete number. The calculator tends to break numbers like these up and, you do not want that to happen. It's a good habit to get into. Post a comment on any questions you may have and, I'll respond quickly.
Jan 25, 2011 | Casio fx-300ES Calculator
My casio fx-992s is showing fix and deg on the screen. I think the "fix" is causing me a problem but I can't get rid of it. All my decimals are being rounded up to whole numbers! Thanks
The DEG is merely indicating that the angular mode is set to degrees. If you want to change it to radians or grads, press SHIFT MODE and make your selection.
Likewise, the FIX is merely indicating that the calculator is displaying numbers in fixed decimal notation. If you're not seeing any digits to the right of the decimal point, then you're in FIX 0 mode. To change it, press SHIFT MODE. You can choose FIX and the calculator will prompt for the number of digits, or you can select NORM.
Nov 29, 2010 | Casio Office Equipment & Supplies
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
I "fat-fingered" something while typing some numbers into my excel spreadsheet, and now only the suport "upper case" of the numbers of my number section work--so I am unable to now type...
Does your k/b have a "shift lock" button... if so press it to disable the "shift lock"
If using the numeric keypad, ensure you have "num lock" ON
HIH
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
