Question about AEG Washing Machines
C9 error code has appeard and the door will now not open
2 Suggested Answers
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
Lg cool art error code c9
Out door fan not rotating.
Apr 21, 2014 | Heating & Cooling
C9 error code lg cool art
let the technicians do it for you,one of their sensor got faulty
Every time it rains our instantanious hot water system comes up with error C9 and C12
Before calling service technician, open following link for Rheem troubleshooting resources including contact and chat and typical manuals:
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are start points for troubleshooting and can include long list of things including multiple causes.
Error code 12 shows 'condensation collar' and 'vent lengths' which are associated with the vent to outdoors. Changes in air pressure during low-pressure rain events MIGHT affect the venting and cause tankless not to ignite, and MIGHT cause excessive condensation. Improper condensation can rust out the heat exchanger without showing any signs of problem until the unit is ruined.
C9 is not listed. Contact Rheem, and then add a comment saying what Rheem suggests as solution for C9 error. This will help others in the community with same-similar problem.
Instruction manual recommends yearly maintenance by qualified service technician.
This maintenance would usually check all things shown in error 12.
Jul 18, 2011 | Rheem Tankless Hot Water Heater...
L.G. AIR CONDITIONER no cooling shows error c9
C9- Out door fan motor mechanism locked, less rpm or no power to Fan.motor.
If mechanism locked, replaced bearing or f.motor./less rpm-replace capacitor./ nopower fan-motor, out door PCB problem -Replace it. Hope helpful?
Jan 22, 2011 | LG LP7000R Air Conditioner
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
Jul 04, 2009 | AEG Washing Machines
AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Aug 18, 2008 | Washing Machines
Washing Machines Logo
234 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
