Question about Microwave Ovens
JCPenney microwave oven model #5919 Electronics panel is failing. After unplugging to wipe it down, I cannot set any functions, the first of which is always the clock. The panel will let me enter one numeric digit, and that's it. I have unplugged the unit for 24 hours and tried again. Same problem. One digit, and one digit only. The cooking functions all worked fine before unplugging it and cleaning it.
  • Microwave Ovens Master
  • 9,086 Answers
It sounds like moisture has gotten into the controls. If it can be dried with a hair dryer or the sun, that might work.
I used to work on a lot of these about 20 years ago, and if it needs to be repaired, I truly doubt that it can be done. One would have to replace several capacitors, at the very least.
Posted on Nov 09, 2008
I have a maytag micro/hood combo that stopped working the other day when it was used. We thought the timer was set for 18 min, however the microwave was actually cooking the entire 18 min. The unit worked...
Try a hard rest of the electronics to restore unit to factory defaults. If that does not do it your logic board has failed and if not too expensive you might want to replace it. Check it out at site Search Over 2 1 Million Appliance Parts
Sep 03, 2017 | Maytag Microwave Ovens
The 'turntable on' feature does not work it reverts to 'turntable off' each times it is set. Please advise
If the display is changing by itself despite your pressing the turntable pad, i would say the turntable pad is failing on the keypad.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then if it still fails, you may have a failing keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Pushing the start button trips the breaker. All functions seems to work, fan, clock etc but it just started as soon as you push start it trips the breaker. Control panel/board seems fine no burn marks.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Genius/Prestige/model.NN-P295SF
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Service manual below, troubleshoot with that. http://www.eserviceinfo.com/downloadsm/5734/PANASONIC_NN-K652.html
May 04, 2010 | Panasonic NN-P295SF Microwave Oven
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
prototech@usa.net
Aug 26, 2009 | Frigidaire Microwave Microwave Oven
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
Aug 25, 2009 | Maytag MMV4205 Microwave Oven
My microwave does not heat. All electronics
chek power level on panel if high if evertthing funcitioons sound lik megatron is bad
Jul 25, 2009 | GE JNM1851DMWW / JNM1851DMBB / JNM1851DMCC...
Press "start," the oven operates briefly (anywhere from less than
I haven't worked on one of these old models for many many years, but I do remember that when this happens, they need to have their electrolytic capacitors replaced.
Chances are the control boards are no longer available for purchase, but we repair them for customers nationwide.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 23, 2008 | Microwave Ovens
GE Spacemaker microwave won't heat food
hello kmwnky,
You say that Everything went out at first ( which I assume means that all functions went dead) and then functions started to operate again later... if that is correct and you smelled something burning.. you may have a thermal fuse that failed, filament transformer that failed, magnetron tube that failed or a highvoltage capacitor that failed.. None of these components are something the untrained person should attempt to trouble shoot or replace since there are dangerous energies stored inside the electronics compartment even after power is removed.. Your Micro is > 8 years old and it's probably not worth the cost of repairing at this point. You'd be better served replacing it.. The cost to repair would exceed the cost to replace.. ( I feel like the grim reaper here..sorry..)
Regards,
Rick
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The main 10A 250V Fuse keeps on blowing up everytime I use my Microwave function. This does not happen when I use the Convection Oven.
Possibly magnatron to earth fault.Needs testing profesionaly.(microwaves can kill even when unplugged.)Regards grandadfixer
Oct 15, 2008 | Microwave Ovens
Microwave Ovens Logo
235 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
