FixYa.com
Tags:
Gateway GTW-P42M303 42 in. Plasma Television
Plasma tv GTW-P42M102 (by 2 users)
posted by vojo on Oct 05, 2006
After the tv is on for about 20 min.it turns off,and i cant turn it back on.After it cools off i have to turn the main power switch off and on and then it powers back on.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 08, 2008
Our television turns itself off after 3-4 minutes. I've had a repairman out. He takes the tv back to the shop for a week and when he returns the problem is still there. He swears that the tv works in his shop. This has happened three times already and he wants to try for a fourth. The last time the TV worked when delivered, but there was no sound. He took the back off and jiggled the connector on the sound board and the sound started working. He put the TV together and I signed off on the delivery, within five minutes after he left it turned itself off again.
Best Solution
posted on Oct 05, 2006
FixYa! (100)
techman
Rank:Guru Guru
Rating: 87%, 6563 votes
Sorry to tell you a common problem with these sets. It is a bad capacitor in the main power supply.. There are really about three of them that go bad from time to time to cause this problem... If your not a tech you should find an authorized repair facility as a non authorized is not going to know what to do to fix it and it will most likly cost you double to repair. Good luck and let us know how you got it fixed.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 06, 2008
Not Rated (0)
lynnjana
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have one I bought about four years ago and am starting to have problems with a refurbished one they replaced after they could not get the original one to work after replacing two of the four parts they were supposed to replace. Any suggestions?
Comment by lynnjana, posted on Apr 06, 2008
What do you think it's worth if it's still working but I can tell the color is going out and the Power is messed up?
Can you Help with these Flat Panel Televisions problems?
Gateway 42" Plasma - no...
Sounds like common problem;... Answer This...
flashing color lines
we had a power outage and when... Answer This...
Gateway GTW-P42M303 42 in...
no matter what button you push,... Answer This...
Gateway GTW-P42M103
need help with Gateway... Answer This...
42 " gateway plasma tv
powers up to green light. no... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
